Adding additional sender for external oil temp
Old Feb 15, 2019 | 12:37 PM
Squirrel13's Avatar
Squirrel13
Since I will be towing the Jeep at high elevations 5-14K ft I wanted the critical A pillar gauges: EGT, EOT, Trans. Dash will get coolant temp, fuel pressure and boost.
I initially was thinking about adding a T to the OEM port on the back of the HPOP reservoir but that would be a huge pipe contraption. New plan is to add the T down at the oil cooler pressure port where I will tie in the oil bypass filter.
Trans temp I will use the port on the side of the transmission.
Coolant temp will be sensor will be plumbed into a port on the coolant filter.
Fuel pressure sender added to the CNC Fab 4 way T at the fuel bowl.
EGT mounted to underside of drivers side manifold.
Boost has a sensor in the intake.
Yes I know EOT is avail via OBDii but I wanted it up on the A pillar. I am waiting for Banks to release the iDash 1.8 Data Monster for the 7.3 in 90 days or so. It can display like 8 gauges at once which I will use for secondary monitoring.
Thoughts, concerns recommendations?
Old Feb 15, 2019 | 09:18 PM
timmyboy76's Avatar
timmyboy76
Nope....have a blast man and good luck
Old Feb 15, 2019 | 09:50 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
I put the sending unit for the 1973 in the oil cooler header just above the filter. There is an 1/8NPT plug there.
Old Feb 16, 2019 | 06:18 AM
Tugly's Avatar
Tugly
Old Feb 16, 2019 | 07:23 PM
Squirrel13's Avatar
Squirrel13
Thats where I outnit
Medline
Jul 21, 2016 02:07 PM
jasonc76
Jun 11, 2014 10:46 PM
86scotty
May 19, 2014 09:51 AM
czthda
Jun 26, 2013 04:01 PM
jarrodh
Mar 16, 2013 10:21 PM
