02 door ajar switch
Received 3,159 Likes
on
Got tired of it. Lubed the little latch fork mechanism and it is better. Shoot some WD or other lube/cleaner into whatever hole you can find for the internal mechanism as well.
on
on
You already found it so I'm late to the party, but the 'self test' feature in the instrument panel will tell you which one it is. With the key off hold down the odo reset button and turn to run and keep holding the button 'till it goes into test mode. Then you toggle the button to cycle through different stuff and one of them is the door sensors, it'll tell you which are open closed. It displays them in a numerical code, you could find which number is which door or just open/close the doors and see which one doesn't trigger a change in the display.
on
on
on
correct you all are. fat fingers here hit 9 instead of 0
04 was the start of all digital.
