Aerostar Ford Aerostar
94 areostar radiator
Old Sep 29, 2003 | 10:12 PM
east79th's Avatar
east79th
I have a 94 aerostar 3.0 its just sitting in the garage and I filled the radiator and it keeps losing anti freeze its none of the hoses its not in the enginine oil and the floor is not wet from the heater core cannot figure out were its going it dosent make sense, let it set for a month and pulled it out of the garage nothing on the floor any help would be greatly helpful Thanks East79th
Old Sep 30, 2003 | 03:41 PM
broncoIILover's Avatar
broncoIILover
well I don't know that much about the 3.0 but I can guess what is wrong with it. My guess is the one or both of your heads a cracked. I have a Bronco II with a 2.9 that did the same thing about 2 weeks ago. I pulled the engine and took the heads off, found that the head was cracked between the intake and exahust valves. another guess is that maybe you blew a head gasket and it is leaking the water into the cylinders. try to pull the spark plugs and see if one of them looks different than all the others. if that does not help any try starting it and looking at the exahust to see if you can see any white smoke. That is all i can think of.. Good luck
Old Sep 30, 2003 | 07:24 PM
eehoepp's Avatar
eehoepp
If you have any suspicion that the coolant is leaking into the cylinders, don't try to start it. If you hydro-lock the engine, very bad things will happen. Take the plugs out before cranking it over. Have someone else crank it while you watch from under the hood. If coolant comes out a plug hole, you know where the problem is.
Cheers,
Eric
Old Sep 30, 2003 | 07:39 PM
broncoIILover
great point, I am only 17 so i am learning along with you. thanks eehoepp. good luck..
Matt
94BULLITT
2009 - 2014 F150
20
Jul 23, 2013 10:36 PM
79 f-150 guy
27
Sep 18, 2009 05:35 PM
79 f-150 guy
16
Aug 6, 2009 12:13 AM
paemtsta31
22
Nov 16, 2007 08:51 PM
oldcoupe42
Jan 16, 2004 02:15 PM
