Foam in Radiator ???
Old Jan 15, 2004 | 03:52 PM
oldcoupe42's Avatar
oldcoupe42
Hi gang, my Pop's 90 F150 302 is "foaming" up in the radiator and is not making any heat. Typical, the coldest day in decades in the North East ! Where should I look for the problem ?
Thanks, Chet
Old Jan 16, 2004 | 10:38 AM
INDO's Avatar
INDO
does the truck overheat?
Old Jan 16, 2004 | 11:20 AM
oldcoupe42's Avatar
oldcoupe42
Truck ran hot initially and heater hoses were warm, filled radiator with more fluid and heat came back. Must have been too low.
Thanks for the reply
Old Jan 16, 2004 | 12:31 PM
99 ranger bob's Avatar
99 ranger bob
only time ive seen foam in a radiator is if you didnt get all the flush stuff outadding fluid for heat is cool but you may nneed to bring it in for a radiator service leaving the cleaner in there isnt good for it
Old Jan 16, 2004 | 01:48 PM
MavStallion's Avatar
MavStallion
Foam is generally indicative of air or something else mixing with the coolant. Does the coolant smell like anything else? You could possibly have a bad head gasket and exhaust is mixing with the coolant. A trick for confirming this is to have an exhaust analyzer probe stuck into the filler neck and see if there is any reading. It still can be as simple as flushing the system and putting a new thermostat in. Try simple first.
Old Jan 16, 2004 | 02:15 PM
INDO's Avatar
INDO
If the truck has overheated, mavstallion may have something.
If head gasket is bad you may have oil in the coolant. check
oil dip stick for moisture as well. (milky color oil is bad)
grang46
Aerostar
Jul 4, 2014 10:31 PM
Gordon Freeman
21
Aug 11, 2010 11:44 AM
pr95bronco
Dec 24, 2004 09:36 PM
jonm61
Dec 15, 2004 07:26 PM
traderguy111
1978 - 1996 Big Bronco
Aug 8, 2004 04:24 PM
