2100 Choke Question
Old Feb 10, 2019 | 07:14 AM
Brynjaminjones's Avatar
Brynjaminjones
2100 Choke Question
I've got a '74 F100 2wd with a 390 and C6. It's got the original 2100 carb with an electric and hot air choke.
I'm having some trouble getting the choke to work consistently. If it's adjusted so that it closes fully, then it doesn't fully open for a long, long time. That will often mean that the truck stays on high idle for ages.
If I adjust it so it fully opens fairly easily, it doesn't close enough to put me onto the high idle cam when cold.
My current thought is that the electric choke heater/thermostat might not be working. I've tested it with a multimeter and with the engine running it receives about 7V. It doesn't however show any kind of continuity from the spade terminal to the metal on the casing.
Some things I've read have suggested that it should only give a resistance reading at some temperatures, but I'm not sure if that's the case.
Does a lack of continuity definitely mean that it doesn't work?
Old Feb 10, 2019 | 09:13 PM
FuzzFace2's Avatar
FuzzFace2
I would think so other wise how would it work?
I have a carter v1 on my 300 but the choke works the same way, hot air & 7v.
I will try and get out to the garage to check mine. I also think I have a Holley or 2 and thinking they must check the same other than needing 12v.
Dave ----
Old Feb 11, 2019 | 04:37 AM
Brynjaminjones
Thanks Dave. I thought the same but a lot of the nonsense on other forums was making me doubt myself - I was after a definitive answer!
I'd really appreciate if you could test yous, thanks!
rb76543
19
Jul 2, 2017 10:28 AM
oft
Jan 1, 2015 01:29 PM
fairfield86f150
42
Mar 15, 2012 02:13 PM
Nathan Plemons
Jun 30, 2009 06:44 AM
65CJ5
Aug 17, 2004 10:59 AM
