Sponsored by: Real Truck
2015 4x4 Front Assembly
Old Feb 9, 2019 | 11:11 PM
MyronJ's Avatar
MyronJ
Question 2015 4x4 Front Assembly
Is there a reason why a person could not buy the NTN6009LU bearing that ford uses in these hubs and just change the bearing instead of the complete hub assembly? I don't see anyone doing this $60 dollar repair instead of changing the whole assembly. Thanks for any input.
Old Feb 9, 2019 | 11:56 PM
GlenPxC's Avatar
GlenPxC
are you talking about the bearing the axle shaft rides on? I just did this while I was in there replacing an axle joint. Bearing is # 6009-2RS-JEM check eBay you can find them cheaper. Get a good set of snap right pliers to remove the lock ring, then it taps out easy.
CuNmUdF250
Jul 7, 2012 04:42 PM
lalevant
Jun 12, 2009 11:47 PM
bubbasz1
Nov 26, 2008 10:50 PM
Madmaxz
34
Aug 11, 2008 09:33 AM
t4kne
Jun 22, 2003 12:22 PM
