390 Cam selection question
Old Feb 8, 2019 | 02:00 PM
njdevil77's Avatar
njdevil77
So I have never worked on an FE block besides the external stuff. With that said I have built a few engines in my life, but I never remember seeing this when I was doing my cam selections " Will not fit factory Ford FE solid lifter engine blocks". I know that there was work done to the engine prior to me owning because it has a kinda rough idle cam that sux off the line in it now, which is my concern for such a heavy truck. My 351m in my 77 had a cam good for making peak power @ 2300-5500, kinda stupid..... I want to put a rv style cam but this * thing keep popping up. It has me a little confused. Any input would be greatly appreciated.
Old Feb 8, 2019 | 03:07 PM
caravaggio2000's Avatar
caravaggio2000
Is this what you are looking for?
COMP Cams: Magnum, 270S <br> Everyday Street Driving, Mild Rough Idle
Old Feb 8, 2019 | 05:49 PM
flowney's Avatar
flowney
Most top oiler FE engines are designed for hydraulic lifters. Here is a decent primer on the subject.
The FE valve train works well with moderate lift. High lift cams will require beefing up the non-adjustable rocker system.
Hope this helps your decision making.
Old Feb 8, 2019 | 06:17 PM
john jamieson's Avatar
john jamieson
Ask on the FE forum further down the page. They will have a lot of info for you.
njdevil77
Feb 12, 2019 02:40 PM
1975MudRat
Dec 3, 2012 09:37 PM
fe8u
Jul 4, 2005 01:11 AM
fordman428
Dec 4, 2003 09:15 PM
