Flatbed mounting
Old Feb 6, 2019 | 11:38 PM
Bluebronco85's Avatar
Bluebronco85
Flatbed mounting
I'm purchasing a Bradford built flatbed on Monday and mounting it myself. I am mechanically inclined and weld on the farm here. I have a 99 CC SB SRW 4x4 4" lift 35's and was looking for suggestions preferably with some pics for how anyone has mounted their beds. thanks
Old Feb 7, 2019 | 09:34 PM
AZGateguy's Avatar
AZGateguy
My F450 Upfitter installed flatbed sits on a 2X4 on top of the frame and is mounted with multiple tabs running vertically and bolted thru the side of the frame, as well as the hitch is welded to the back end of the frame.
Old Feb 7, 2019 | 09:50 PM
beef tits's Avatar
beef tits
1st thing I would do is beef up those rear springs... That backwards rake is not good. A lot of lift kits "level" the truck which is all fine and dandy if it is a grocery getter but if you are hauling 5th wheel or any real weight it's not safe to have the rear end sitting lower than the front like that loaded. It effects handling and stopping pretty significantly. Unloaded you want 1.5-2" of rake in the rear. (rear higher than front)
As for the flatbed, they aren't all that complicated. They just bolt to the frame and you wire in the new lights, find a new spot for your license plate. I wouldn't weld it to your frame.
Old Feb 7, 2019 | 10:18 PM
timmyboy76's Avatar
timmyboy76
The crossmembers on a normal sd bed will make up for the contour of the frame. It aint no slap n go build. If anything, build up a "deck" so that the flatbed will lie true...you either go flatbed or dont. If you do, then you plan to tow/haul which in case, id weld everything...
Old Feb 7, 2019 | 11:55 PM
AZGateguy's Avatar
AZGateguy
True, I forgot that the pickup frame has a small kickup over the axle VS the 450 Cab and Chassis is flat all the way back.
I would still bolt the flatbed down along the frame similar to what I showed previously, with the appropriate spacers between the frame and the flatbed underframe, then weld the hitch mounts at the back for strength, also consider Airbags for load handling/leveling under load, the bags will not raise your GVWR but will help keep things level and rolling smoothly for better control while rolling.
The tail lights should wire in very similar to wiring a trailer, get the wiring diagram for your year and you should be able to sort it out, if not, post up and we would be glad to assist from our keyboards.
Old Feb 8, 2019 | 07:35 AM
Bluebronco85
yea....I pull a lot with that truck and I don’t typically have it squatting like that and use load levelers on my other trailers. That storage container was loaded very tongue heavy and I only had to haul it 30 miles. It was simply a pic I had in my phone. I haul my 4610 tractor with loaded rear tires with 8ft bushhog, it comes in at 13k trailer and all. But yes it needs a stiffer spring in the rear. The Procomp lift was in it when I got it and I wasn’t planning on welding anything to the frame I was referring to welding tabs and mounts to the flatbed itself. Thanks again.
Old Feb 8, 2019 | 07:38 AM
Bluebronco85
when I wire my 7 pin plug I pig tailed the connections so I can unplug it and wire a plug on the new 7 pin in the flatbed in case I ever remove the bed for some reason, that was my plan at least.
Old Feb 8, 2019 | 07:54 AM
Bluebronco85
As for the flatbed, they aren't all that complicated. They just bolt to the frame and you wire in the new lights, find a new spot for your license plate. I wouldn't weld it to your frame.[/QUOTE]
The bradford beds and most others have the license plate mount on the rear.
Old Feb 8, 2019 | 07:58 AM
Bluebronco85
This is what I was hauling with most of the time. I decided it was time to have just one truck and stop paying insurance, maintenance etc on 2 trucks. It was a 93 idi non turbo it did its job but it’s no powerstroke when I comes to pulling in the hills that was part of my decision to part with it also.
Old Feb 9, 2019 | 07:39 AM
tjc transport's Avatar
tjc transport
i ain't rite
they should had two different with frame available, make sure you get the one for your truck. the pickup has a wider rear frame section with a hump over the rear axle . the dual rear wheel cab chassis trucks have a narrower rear frame without the "hump".
if you order for a pickup frame, it will make mounting much easier, and should come with the subframe to bolt directly to your pickup frame.
SpencerS
28
Jul 1, 2018 12:59 PM
penjaksilat
Ford Truck Parts for Sale
Dec 31, 2014 10:18 AM
BDawg171
34
Jun 14, 2013 02:59 PM
rsalter66
33
Dec 4, 2008 08:11 PM
Goobzilla
Oct 8, 2004 11:10 AM
