Sponsored by: Real Truck
Brake switch keeps going out.
Old Feb 5, 2019 | 09:31 PM
magman25's Avatar
magman25
Need some help. My 2011 F350 6.2L brake lights stay on when the pick up is turned off. Causing the battery to drain and run in “limp mode” when started. It happened for the first time last week, and I troubleshot it down to a faulty brake switch. Once I replaced it, lights stayed off and truck ran normally. Fast forward to today, and the wife said the brake lights were back on again. I’ll replace brake switch when I get back in town, but could there be something electrically causing the brake switch to go bad???
Old Feb 6, 2019 | 08:53 AM
Chuck's First Ford's Avatar
Chuck's First Ford
what about the install of the switch... did it LOCK into place.. or has it Moved ???
loose or not locked will cause the light to stay on..
its a simple mechanical pressure switch.. no pressure on switch.. its ON..
Old Feb 6, 2019 | 08:56 AM
magman25's Avatar
magman25
It is installed correctly and locked into place.
Old Feb 8, 2019 | 01:38 PM
magman25's Avatar
magman25
Here is the latest info on what's going on. So the brake lights are shutting off when I turn the truck off. Then for no rhyme or reason the brake lights will just come on. I replaced the brake switch again to rule it out. No change. Thought maybe a rat had gotten under hood and chewed on something, but have not found any signs of that happening. Anybod hav any thoughts on what the cause might be???
Old Feb 8, 2019 | 07:42 PM
o7dgm's Avatar
o7dgm
I had a 78 F150 that the brake pedal would stick enough to hold the switch on.had to oil the brake pedal .
Redonkulous BOB
Dec 22, 2011 12:44 PM
tardster
15
Apr 4, 2010 06:15 PM
blue52f1
Sep 3, 2006 01:24 PM
samralh
Oct 14, 2004 11:50 PM
