7.3L kill resale value of 6.2L
#241
I used to have a '97 F-250 RC 4x4 with a 460, great truck, always got 12.5mpg empty or loaded. The new 7.3 should at least do that. I am also considering this new engine in my next F-350, gotta see what the numbers are. Maybe I will end up having 2 7.3L trucks, or I may just keep rolling with my old and trusted Powerstroke.
#243
Supposedly the 7.3 will also fit the Raptor and Mustang, whether ford does it or not is another thing.
https://www.torquenews.com/106/new-f...tang-and-f-150
#244
#245
#246
mine is payed for, however my biggest fear in the back of my mind is the cost of a catastrophic fuel system failure....injectors, cp4 etc. That can really really put a dent in your wallet
Had to replace injectors on my 2007 5.9 cummins from two bad loads of fuel. i thought that was expensive doing my self compared to the old heui injectors of the 7.3 or even cheaper idi or p-pumped cummins.
#247
You interest rate must suck. At 0% it would be an extra 166 a month. At a decent interest rate is should not go more than 200 a month more. Your 3500 per year would be about 290 a month.
#249
When I was toying around with the 6.7 purchased this is all I had on my mind. I don't trade in every few years, I will own this out of warranty. I keep my trucks usually 15 years or so. But I only tow 10-15 times a year just during summer, I drive maybe 500 miles a month, my commute is 2 miles round trip and I live where the temps go to zero. The 6.2 has been working out good so far. I couldn't fathom a 10K repair out of warranty.
#250
The diesel MSRP is about $9300. If bought at invoice, that’s about $8500. At $18.83 per $1,000 X 8.5 is $160 per month for 60 months at 4.9%. Could be over $170 if you want to consider tax on the diesel option.
Financing $10k over 5 years is not costing $3,500 a year. That’d be costing $17,500 for the engine with interest over 5 years. The $8500 invoice diesel is actually costing a buyer $9600 without tax over 5 years.
#251
#252
Interesting article on the 7.3 https://www.msn.com/en-my/cars/news/...EpO?li=BBr8YXE
#253
#254
well just like guys buy diesel trucks that don’t need it. so are the guys buying a HD truck with a 6.2. It’s not enjoyable to drive a big truck all day with drive ups, parking garage, small parking lots. An f150 will do almost all the needs a 6.2 f250 will and be more comfortable. You are just wanting a big truck . Yes commercial applications will use gas and I own a business and understand that but for the guy who buys a fully loaded gas f350? Maintenance cost? That’s an excuse. I haven’t done a thing to my truck other then regular maintenance. Same as a gas truck.
I greatly appreciate the added stability, lower gears, bigger brakes, and better suspension when towing my equipment trailer here in the Appalachian mountains. No white-knuckle rides in a F150 for me. I also appreciate the strength of a solid axle, and added ground clearance when I journey off the pavement. None of which I need or want a diesel for. I've owned 2 late model Cummins powered trucks previously...so I am no stranger to them.
And yeah, a diesel's maintenance cost is higher than a gasser. So is the fuel. So is the initial purchase price. And many times, insurance is higher too.
So like I said before, a gas powered SD fills a large market for people who need or want a HD truck without needing/wanting to tow 20k+ lbs with a $9500 engine option. That's it. Sorry you don't like it.
#255
Gas or diesel HD trucks are fine. Most guys that are doing "real work" use gas powered HD trucks. They are cheaper to buy, cheaper to maintain, and have more payload. The only commercial guys I see running diesels are those who really need to tow something heavy.
I've had both. I like the diesel better. But the gas engine is completely fine, and I'm talking about the 6.2L. The 7.3L will be even better.
