7.3L Gasoline V8 Engine Discuss the new upcoming 7.3L V8
7.3L kill resale value of 6.2L
Old 02-05-2019, 12:00 PM
boxrbus's Avatar
boxrbus
boxrbus is online now
boxrbus is starting off with a positive reputation.
With Ford officially unveiling the new 7.3L gas engine today, how will this affect the resale value of existing 6.2L gas engines. I know it will hurt new 6.7L diesel sales, but this could be more devastating to the smaller, less powerful gas engine in the used truck sales market.
Old 02-05-2019, 12:05 PM
Blwnsmoke
Blwnsmoke is offline
Blwnsmoke is gaining momentum as a positive member of FTE.Blwnsmoke is gaining momentum as a positive member of FTE.
Why would it hurt 6.7 sales? 6.7 will tow more, be more powerful in both HP and TQ.. I do not see it hurting sales.. lost who buy the 6.7 buy it because it is a diesel and that's what they want. Majority of people in a 6.7 could have a 6.2 but just choose not to.
Old 02-05-2019, 12:10 PM
RandyinTN
RandyinTN is offline
RandyinTN is starting off with a positive reputation.
Itís an option. The 6.2 will still be here and dealers will order them to keep the costs low on the lot inventory.
Autos and trucks get upgraded just about every year. Doesnít automatically mean the old model is worthless.
Old 02-05-2019, 12:13 PM
Ben Elliott
Ben Elliott is offline
Ben Elliott is starting off with a positive reputation.
Originally Posted by Blwnsmoke View Post
Why would it hurt 6.7 sales? 6.7 will tow more, be more powerful in both HP and TQ.. I do not see it hurtimg sales.. kost who buy the 6.7 buy it because it is a diesel and that's what they want. Majority of people in a 6.7 could have a 6.2 but just choose not to.
on a personal all level it probably wont but since DEF has come into play- Govt- large commercial fleets have been starting to switch over to gas engines because of cost of diesel/def/maintenance. It will be interesting to see the price point of the 7.3- maybe half the cost of a diesel upgrade around $5k maybe-especially if the numbers of the new engine look promising.
Our conpany decided 4 years ago to buy the dodge 4500 with the 6.4 Ďs and have been incredibly cheap to maintain.
Old 02-05-2019, 12:17 PM
Poncho450's Avatar
Poncho450
Poncho450 is online now
Poncho450 is gaining momentum as a positive member of FTE.Poncho450 is gaining momentum as a positive member of FTE.
From the video that I watched, the Ford engineer stated that for numbers it should come down squarely between the 6.2 and the 6.7 but would not yet give specific specs. He said the physical layout of the engine itself allows it to be spread across more platforms from F250 up into the 550 or so medium duty trucks.
I'm guessing that we'll have to wait and see if the price point is worth the extra bang before folks determine if they should move on from the 6.2. If they price it less than the $9k or so diesel option they'll get some converts I'm sure.
On paper it sounds like it'll be a good combo mated to the new 10 speed. As with all things, time will tell.
Old 02-05-2019, 12:19 PM
smokewagun
smokewagun is offline
smokewagun has a good reputation on FTE.smokewagun has a good reputation on FTE.
I think we are more likely to see no more further improvements on the 6.2L to prevent it from undermining the 7.3L.
The 7.3L will undoubtably hit the 6.7L sales. I think many buyers know they donít need a Diesel, and the distance between the 6.7L and the 6.2L was just cut in half. True haulers will never recognize the Gasser, but weekend warriors and big truck wanna beís that realize the $10k hit and expense arenít worth it, will sail off into the sunset in a 7.3L that will soon have a boatload of aftermarket exhausts and tuners that close the gap even more.
I think this is a precursor to something else ford has up them sleeve. Itís not that an Ecoboost for the Super Duty is necessarily in the wings, but a few short years ago, people griped about a V-6 in a truck. Now itís selling like hot cakes and most are pinning it against the 3.0L baby Stroke as the leader. I could easily see the 7.3L as a stepping stone to use of a high mileage and higher mpg offering on the design table in the bowels of Headquarters in Detroit.
Old 02-05-2019, 12:50 PM
RandyinTN
So much depends on:
Option cost of the 7.3
How much more HP and torque.
In a heavy truck you would be hard pressed to notice 40-50 hp and torque by the old butt dyno. More, and you can tell. But what does more cost? Maybe Ford is holding the option hostage to Limited or Platinum levels?
Time will tell.
Old 02-05-2019, 12:53 PM
acadianbob's Avatar
acadianbob
acadianbob is offline
acadianbob is gaining momentum as a positive member of FTE.acadianbob is gaining momentum as a positive member of FTE.
I don't see the 7.3 as the motor for "the masses". The 6.2 will suffice for many people. The 7.3 is a serious truck engine. Many people will not need it.
Old 02-05-2019, 12:57 PM
Busa 1 Dave
Busa 1 Dave is offline
Busa 1 Dave is gaining momentum as a positive member of FTE.
Yes the 7.3 is a more advanced engine design that will eclipse the 6.2. The new 7.3 HD was designed with a specific output range with the new 10 speed. The 6.2 design was running 4 speed transmissions and needed a different RPM band TQ curve. Lot more to it but you get the idea. Stick a fork in the 6.2 it is done --- hell I would never even consider it but the new 7.3 may just be my next truck motor. May just forget the new GMC HD with the relocated DEF tank!
I am looking forward to the big engine and 10 speed. Will hopefully have all of the same "hd cooling features" of the diesel since it is the real engine for the HD series trucks whereas the 6.2 will be for the light duty kind of like when there was a F250 and a F250 HD truck lol.
The existing 6.2 "light duty" people are going to be disappointed but hey improvements must go on.
Old 02-05-2019, 01:04 PM
wrvond's Avatar
wrvond
wrvond is offline
wrvond has a very good reputation on FTE.wrvond has a very good reputation on FTE.wrvond has a very good reputation on FTE.wrvond has a very good reputation on FTE.
If I quit towing for a living there's a whole list of things I'll no longer need:
1. diesel
2. long bed
3. fifth wheel hitch
4. dually
5. 7.3L
I'm really thinking that for pulling my 27 foot travel trailer the 6.2L coupled to a 4.30 rear end is more than sufficient.
In fact, I'm starting to seriously consider being one of those guys jumping on a new 2019.
Old 02-05-2019, 01:05 PM
BowtieConvert
BowtieConvert is offline
BowtieConvert is gaining momentum as a positive member of FTE.
Not only did you just poke the hornet's nest, you took a whiz on it and then drop-kicked it! Be prepared for the wrath.
Old 02-05-2019, 01:07 PM
ncl
ncl is offline
ncl is gaining momentum as a positive member of FTE.
If the 7.3 costs 5k as an option they wont sell well. The v10 was around a 600 option. I bet in today's dollars the 7.3 will be 1k-2k. They would have to sell it in all trim levels for fleet sales.
Old 02-05-2019, 01:16 PM
wrvond's Avatar
wrvond
wrvond is offline
I'm looking to move into the "light duty" classification. F150 is too light duty - BTDT. But an F250 with 6.2 and short rear gear can be a wonderful thing.
As long as there are guys trying to tow fifth wheels with F150's, I think there'll be a market for 6.2L equipped trucks.
Old 02-05-2019, 01:39 PM
SDcrewzer's Avatar
SDcrewzer
SDcrewzer is offline
SDcrewzer is gaining momentum as a positive member of FTE.SDcrewzer is gaining momentum as a positive member of FTE.
Lightbulb
The V10 option was an even better bargain than it appeared, at least back in 2000. The upgrade included a larger radiator, a tighter torque converter in the 4R100, and IIRC, and three spider gears (instead of two with the 5.4) in the rear differential.
Regards,
Jim/ crewzer
Old 02-05-2019, 02:06 PM
FastTaurusSHO
FastTaurusSHO is offline
FastTaurusSHO is starting off with a positive reputation.
Agreed. For fleets that are running a F550 or F650 and are loaded with 8K+ of payload constantly, I think the 7.3 makes a lot of sense for municipalities that don't need the expense or efficiency of the diesel, and it really sounds like that is the target audience based on the lead engineer comments.
The 6.2 for daily driving and tows 11K lbs. 8 or 10 times a year might be the more sensible engine, especially when in an F250 with the G tranny.
Of course, there will be those that must have mo powa, and so will buy the 7.3
For me it would depend on cost and efficiency compared to the 6.2 V8, honestly I really don't feel like I need more power, but there are many who tow much heavier than my 8K Travel Trailer.
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
