2017+ Super Duty The 2017+ Ford F250, F350, F450 and F550 Super Duty Pickup and Chassis Cab
2020 revealed!
  #301
Old 04-25-2019, 10:06 AM
porthole's Avatar
porthole
porthole is offline
Second picture
  #302
Old 04-25-2019, 10:44 AM
davidpacificnw's Avatar
davidpacificnw
davidpacificnw is offline
Originally Posted by porthole
Second picture
I prefer the look of the current version. This seems a little less intimidating in someone's rearview mirror.
  #303
Old 04-25-2019, 11:13 AM
Lariatdriver's Avatar
Lariatdriver
Lariatdriver is offline
The current model has those large 2 bars that restrict air flow. This looks a little more cooler for the motor in hot climates. Ford also takes air directly from the grille to feed the motor, looks like Ford is improving their design.
  #304
Old 04-25-2019, 11:30 AM
nick112288's Avatar
nick112288
nick112288 is offline
Could be angle, light, white color, mix of the 3, but I'm not a fan of how the hood looks from the front.
  #305
Old 04-25-2019, 11:49 AM
Alaskan_Warbird's Avatar
Alaskan_Warbird
Alaskan_Warbird is offline
Second picture
SEXAY!! If they offer the 2020+ F450 with the new 7.3L gas, that'll be my next truck.
  #306
Old 04-25-2019, 11:55 AM
dksmith17's Avatar
dksmith17
dksmith17 is offline
But those 2 large bars (specifically the part in between the C) make the C light design pop big time, and the C light design is an optical illusion of sorts and makes everything look big/aggressive. I think the C lights are the main driver behind the look of this gens SD. The 2020 version just blurs and looks like a big grill instead of focusing your attention on the headlights.
It appears the engineers won over the marketing dept this time. I think the billet type (all one piece of aluminum/chrome) in the upper trims looks OK, it reminds me of older gens. If the lower trims are all plastic and have that design I think they will really dissapoint.
  #307
Old 04-25-2019, 12:37 PM
ZAR2USA's Avatar
ZAR2USA
ZAR2USA is offline
Is it just me or does the engine hood appears to hold more volume in height?
  #308
tony m 6.7's Avatar
tony m 6.7
tony m 6.7 is offline
Has Ford released HP and torque specs on the '20's yet? Just curious.
  #309
Old 04-25-2019, 12:39 PM
Alaskan_Warbird
Nope. Not yet. We're eagerly awaiting and discussing in the new 7.3L sub-forum.
  #310
Old 04-25-2019, 03:10 PM
Lariatdriver
The Ford truck regardless the grille is the best looking truck on the road. I changed out my two bar grille for better air flow.
  #311
Old 04-25-2019, 03:14 PM
Lariatdriver
I’m betting on big numbers from Ford. More HP usually means more heat , I’m curious how they’ll keep it cool. Could we see 500 HP?
  #312
Old 04-25-2019, 04:09 PM
Y2KW57's Avatar
Y2KW57
Y2KW57 is offline
Received 3,510 Likes on 1,843 Posts
It could be just you, since it would be entirely reasonable to forget what a stock 17 up super duty hood looks like given the raptor front clip on the F-450 in your avatar.
Do you have, or know the location of, larger sized images of the modified truck in your avatar?
Is it just me or does anyone else want to see a bigger pic also?
  #313
Old 04-25-2019, 06:57 PM
George C's Avatar
George C
George C is offline
Originally Posted by pennsylvaniabo
Am i the only one who wishes they would just leave the bodies alone and give it a good production run/interchangeability like the older superduty's??
Yes, you may be the only one. I went GMC this last time around because I was sick of buying the same truck style over and over.
The new design rocks.
I was not a fan of the17’-19’ C clamp LED piping. I much prefer the 20’. It just doesn’t flow..
The Grille? I like the 17’-19’ better.
I definitely do not like the Non DRW grille. The new Limited has the best looking grille and definitely the best looking interior of the bunch.
  #314
Old 04-25-2019, 07:21 PM
jetskiaz's Avatar
jetskiaz
jetskiaz is offline
You could just buy this Grill for Ultimate flow. 2017 f250 in AZ!
  #315
Old 04-25-2019, 07:26 PM
Lariatdriver
I bought the chrome version of your grille off eBay for $169.00. It fit like a glove.
Quick Reply: 2020 revealed!
