Winter cold fronts
Old Feb 4, 2019 | 11:43 PM
Biz_Bomb's Avatar
Biz_Bomb
Winter cold fronts
New owner here...live in SD where it’s currently consistently below 0° temps right now. What’s a good cold weather grille cover for my 6.7L Lariat Ultimate!?
Something that not only functions the way it’s supposed to...but still looks good too. Do they ALL attach to the outside or is there an option that would go behind the grille and be less conspicuous / cleaner?
Old Feb 5, 2019 | 03:10 AM
seville009's Avatar
seville009
Can’t tell if it’s gas or diesel, but there is a thread about this from a few months ago where I recall someone explaining that it’s not good to put them on at least gassers because it can screw up the computer and airflow computations and such.
I’ve never had issues with gassers in subzero temps.
Old Feb 5, 2019 | 05:00 AM
tortue71's Avatar
tortue71
Never had a problem with my diesels in the cold either !
Old Feb 5, 2019 | 05:12 AM
Dim Sum's Avatar
Dim Sum
I'm running one here in VA (the Fia). The snaps are stick on or you can screw them down. I didn't want to use it, but the truck would not get to operating temperature during my 22 mile commute until around mile 15 when it was below 20 out. That's no good if you want your DPF to regen. The truck has to be at operating temperature.
Between plugging my truck in and the winter cover, I'm now able to get to operating temperature with about 5-8 miles of highway driving.
Old Feb 5, 2019 | 05:43 AM
smokewagun's Avatar
smokewagun
I’ve run Fia fronts for a while now. I get the bug screen and winter front combo. The screen keeps the radiator clean from bugs, and keeps it cooling it’s best. You’d be astonished at how many it catches.
Currently, I run both on my 5.0L gas 5.0L. It comes off at 20 degrees or above. Never an issue.
You may find inserts instead, but you’ll never get something easily behind the grille because I’m of the hard cap above the radiator that has about a dozen fasteners.
Old Feb 5, 2019 | 08:21 AM
HRTKD's Avatar
HRTKD
Biz Bomb, welcome to FTE!
Try running without the cover and see how your truck does. If you have the 6.7L then you probably have the supplemental heater which will give you some heat right away.
Old Feb 5, 2019 | 09:03 AM
Biz_Bomb's Avatar
Biz_Bomb
It is a diesel. We have been hovering around 0° for our daytime HIGHS and -20° straight temp (-30 to -40°) windchills the past few weeks. Truck struggles to get over 165°. Unfortunately my work commute is less than 10mins each way...so any help I can give the ‘ol girl to warm up the better...ESPECIALLY if I take it out on the highway for any distance driving in these temps
Old Feb 5, 2019 | 09:26 AM
HRTKD's Avatar
HRTKD
I'm not sure my truck would warm up much past 165° in 10 minutes even in the summer. By 15 minutes it's probably at operating temps. I think my transmission comes up to temp faster than the engine does.
Old Feb 5, 2019 | 09:38 AM
Biz_Bomb's Avatar
Biz_Bomb
haha...this is where my "diesel ignorance" comes into play. This is my 1st Ford...1st 3/4 ton and 1st diesel pickup. Been a GM (Sierra Denali) owner and just jumped brands. I'm used to seeing 190-200 deg engine temps. I didn't realize 160 was "normal" on these things. LOTS of learning ahead for me...that's why I love these forums where people like you all here are willing to help a newbie like myself!
Old Feb 5, 2019 | 10:08 AM
HRTKD's Avatar
HRTKD
I'm on my first diesel also. I've soaked up a ton of knowledge in the past three years.
I think the normal operating temperature is closer to 200 degrees F. It just takes a good while to get there.
Old Feb 5, 2019 | 11:10 AM
Retiredout's Avatar
Retiredout
My 2015 Ford Lariat had louvers behind the front grill that stayed closed till it got to a certain temperature then opened up. This was all done automatically. My 2019 F 250 6.2L gas has none of this.
Old Feb 5, 2019 | 11:45 AM
Biz_Bomb's Avatar
Biz_Bomb
Interesting...were the louvers easy to spot? Maybe I need to crawl around and see if I have them...
Old Feb 5, 2019 | 06:23 PM
Retiredout's Avatar
Retiredout
Looking through the grill I noticed something. Got a flashlight and again looked through the grill and saw them. I started the truck one winter morning and stood looking through the grill waiting for them to open. And then I saw the louvers open. Again this was on my previous 2015 F150 Lariat and not on my 2019 F 250 6.2L gas truck.
Old Feb 5, 2019 | 06:33 PM
smokewagun's Avatar
smokewagun
I’ve seen the louvers, but putting the winter front on my 2018 has me toasty as can be. A noticeable difference. The winter front seems to work better... especially at -32.
With my 2017 6.7L, the supplemental heater seemed like a waste of $250. The winter front on a Diesel below 20 degrees is a very nice add.
Old Feb 5, 2019 | 07:34 PM
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
We install these daily at work. I use a local upholstery shop that uses arctic vinyl. Center zipper and snap on. These are all work trucks so the snaps aren't of concern like they would be on a personal truck. We put them on everything that goes north where it can be -40f w/o windchill for weeks on end.
These are all gasoline trucks, yes you'll even spot a 19 f150 in one photo.
