Main leaf spring indents
Old Feb 4, 2019 | 10:35 PM
shawniganlakeF250's Avatar
shawniganlakeF250
Hey all
i have a 1979 f250 4x4 chassis with a 76 body on it.
noticed that i had a 2 cracked (one completely missing section) rear leaf springs the other day. ended up getting another set off a parts truck. on further inspection i noticed some indentation where the ubolt retainer plate would sit.
see attached pics. obviously they have seem some wear but would they have come with any indention from the factory or is this just from rust, i haven't taken my old ones off my truck yet. i am a little tight to buy brand new springs right now so i hoped these would get me by for the time being.
(also got some highboy front leafs as well, the seem to be in much better condition)
Old Feb 4, 2019 | 10:39 PM
1TonBasecamp's Avatar
1TonBasecamp
I don't believe I've ever seen a main leaf dimpled or dented or formed specifically for a top plate, or even done by a top plate under "normal" wear circumstances.
That looks to me like a combination of high mileage and high moisture taking their toll on the leaf. Basically rusted into that condition.
Paul
Old Feb 5, 2019 | 06:20 AM
ATS Junior's Avatar
ATS Junior
SPONSOR
Just older springs that are pitting and worn down. Didn't come like that from factory.
Old Feb 5, 2019 | 09:34 AM
shawniganlakeF250
Paul
ya thats what i figured. ill clean them up and see if i cant make them work for a bit. start savings for a new pair or maybe get my other ones rebuilt.
Old Feb 5, 2019 | 01:58 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
X2 on them old ones of yours are worn out. And correct NO indention's for the top plate. Do not get all excited to early about them USED HB front leafs, they can look good and settle flat in no time. Did you see them installed on the truck they came off of and did it have a motor in it?
Good luck with them. A pic of ol blue with front HB leafs and the PO's idea to fix the problem of the front sump oil pan (swap in car 460) being hit by the front axle pumpkin due to the WORN OUT HB leafs. BLOCKS...block head. NOW has a proper lift, without blocks.
Wandering Dixie
Apr 3, 2019 12:52 PM
hamr56
22
Jan 24, 2018 06:21 PM
df85732
Feb 27, 2017 07:38 AM
Jayme Duty
34
May 16, 2011 01:05 AM
Huntfamily53
Sep 1, 2009 08:11 AM
