overload springs
Old May 11, 2011 | 07:58 PM
Jayme Duty's Avatar
Jayme Duty
overload springs
I am not sure if i need a new spring or what happened here. I went to change my rear axle seal on the pass side and noticed that my spring looked very flat. I took off the tire on the drivers side and sure enough it has much more arch to it. Here are a couple pics. anybody seen this? should i just go the junk yard and get a new one?
Old May 11, 2011 | 08:06 PM
Aune163rd's Avatar
Aune163rd
Looks like someone, PO maybe overloaded one side of the truck and didnt balence the weight properly.
Old May 11, 2011 | 08:13 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
looks like its time for a new set of auxiliary springs.
you should replace both sides.nows the time to double or triple them up too if you haul much......which sure looks like you do lol.
Old May 11, 2011 | 08:19 PM
Aune163rd's Avatar
Aune163rd
I need to do the same, got the original 5 from the factory in 1984. How many would you go with for lots of hauling?
Old May 11, 2011 | 08:41 PM
FORDF250HDXLT
how heavy do you carry Aune? ......and/or,how heavy do you want to carry?
Old May 11, 2011 | 08:42 PM
catfish101's Avatar
catfish101
I put a set of these on one of my trucks and have been happy with them. Really helps rolling to the side when you are heavy. Rides fine also.
Vehicle Suspension Kits - Timbren Suspension Enhancement Systems
Old May 11, 2011 | 09:06 PM
Aune163rd's Avatar
Aune163rd
I am hauling ton of hay at a time. I want to be able to hold maybe 2 tons-3 tons of hay.
Old May 11, 2011 | 09:11 PM
Jayme Duty's Avatar
Jayme Duty
I just hauled 4000lbs of gravel in the bed of mine and it didn't mind it at all. I was thinking of just ditching those and going for airbags but not sure. $$$
Old May 11, 2011 | 09:15 PM
catfish101's Avatar
catfish101
I like the Timbrens better then airbags. The weren't very high either. If I can remember they were cheaper then springs.
Old May 11, 2011 | 11:07 PM
oreocreaming's Avatar
oreocreaming
Air Suspension Pros | Find Quality Suspension Lowering & Lift Kits cheap bags man. you can get em "buy 2, get 2 free" small compressor will do you just fine, 3/8 valve up, 3/8 down or just run a $7 ball valve or even just run a .89 schreader valve and your good to go. the ones i got are 3800 lb each bag. the spring is simple, instant and thought free overload protection but you gotta sink it a bit before they kick in. with airbags its instant start to finish. if you have a cheap little compressor you can actually use it like i do, set em up to lift your truck when fully inflated. puts a killer tilt on the trailer so its much easier to load/unload.
Old May 12, 2011 | 07:07 AM
Dodge/Cummins's Avatar
Dodge/Cummins
I like the adjustability of air bags.
At one time I had Firestone air bags and 19.5" wheels on a Dodge Diesel, you could put a HUGE camper on it, pump up the bags and have unreal stability.
When I got to my destination I just let the air out of the bags so it woudn't ride like a buck-board.
Old May 12, 2011 | 08:41 AM
oreocreaming
only way to set up your airbags with a camper like that is have them not tied together at all. Independent fill and drain valves. If they are tied together, as you tip one way, the air goes out of that side and into the other actually making it worse. If they arremt together then each side stay the same pressure and height keeping it even the whole time
Old May 12, 2011 | 10:15 AM
snaponprofile's Avatar
snaponprofile
Mine looks like this, PO set her up to haul.
Old May 12, 2011 | 10:44 AM
punkandpissed138's Avatar
punkandpissed138
lol heres my personal input....get airbags man..preferably air lift..i got the 5000LB bags on the rear and the frontbags that sit inside the coils..!!! i love them!!!! haha..keeps the back up nice and high when im doing a scrap job. 100000% worth it in my opinion..and when not hauling anything..keep em at 8psi and theyre smooth.
Old May 12, 2011 | 10:45 AM
punkandpissed138
ill post some pics when i can upload some]
