1966 390 Original?
I'm pretty sure that the 352 was the largest engine offered in 1966. The 390 was the same block as the 352, because I blew the 352 in my "66" and replaced it with a 1969 390. Bolted right in no problem.
Brian
But the biggest you could get in 66 was a 352.
My 66 has a 390 in it... as its a common swap in.
But its not stock in any way at all :P
FoMoCo did produce, have, and deliver a limited amount of FEs W/ 335hp X 390 CID to "certain" individuals. It was about as common as the Ranger Pkg with buckets carpets, cab back panel etc etc.
I prepped, serviced & delivered one to a big wig from FoMoCos Mawah NJ Assembly Plant in the fall of 1965. It arrived at our dealership via Nu Car Carriers, the contracted carrier of FoMoCo.
We had the "CO' which was in the delivery packet w/ the F100 when it showed up. So I would tell you it was under the counter, or as we used to call stuff like that, "OBD" [ for Out Back Door] of FoMoCo. Besides that there were TASCA FORD, LARSEN FORD, & who knows how many Dealers building "one offs" at that time also. FBp
Barry
What the books say is that 352 was the V8 offered in trucks in 65/66. Ford Truck 390's were produced from 68 to 76. Having said that though, 390's were common in cars such as Galaxies and LTD's. I have a 66 LTD with numbers matching 390 4v. So it is possible that it was special ordered that way, but like I said before, Fordboy would probably know since he worked in the factory.
(climbs down from soapbox)
Tim
Barry
William & Barry both have the solutions. As William suggests, measure the stroke & do the math to determine the actual CID,
of the engine in the truck now.
As Barry suggests, post the Door Data Plate info for us, if you're squemish about posting your serial number on line, make last 6 numbers/ digits of serial number asterisks/ X's or something. The rest is application ID characters.
FWIW & As a point of order; Prior to Federal Mandate of 1968, when P-Cars got marker lamps, locking steering, and those little tags on L/H corner of dash that can be seen thru w/shield from outside, all vehicles had Serial #s, Post or after 88 they're VINs.
Also almost every FE Block I ever saw had 352 emboss cast on it. That includes 1958 - 332s through 428 SCJs.
Scamardo,
THANX for your kind words man! I appreciate them.
FWIW I worked closely WITH Factory but paychecks came from dealer I was employed by. They sponsored a Drag Car back then I wrenched on it. Dealer would not match Fords funds. We ran a burgandy 427 SOHC T-Bolt. in 63 & 64
We never dominated because we lacked funding. Dealer thought,
"Henry" should foot the bill, SVO wanted help with it. Could have been a big deal but wound up a big waste instead. During Days I was mostly a line tech at that dealership. We raced on our own time & our own dime, for free all our team members did that. But Dealer did pay travel & provide equipment too.
We did a lot of stuff because factory felt competition between big 3 Manufacturers. There was a point there where FoMoCo ran at INDY, LeMans, NASCAR, the old TRANS AM Series, NHRA, & AHRA as well as many independent venues, all at the same time. They would do just about anything if you got ahold of the right person in Dearborn or Livonia & had legitimate references etc.
In fact it wouldn't suprise me that's what started what became SVO & SVT divisions and the old Ford Motorsport banner. Among the personalities were Jack Roush, Carrol Shelby, Connie Kalitta, and others. Forgive me guys, I'm "Pine - ing" here as I recollect!
FBp.
FORDBOYpete- Quick question. Did SVO stand for Special Vehicle Operations? And did that division of Ford become SVT?
It became SVT and Ford Motorsport became Ford Racing. I don't know why. Here's what they were originally though, SVO=Special Vehicle Operations & SVT = Special Vehicle Technologies. . . . .
FBp
