Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
2003 escape acting sluggish
Old Feb 4, 2019 | 01:47 PM
hg3300's Avatar
hg3300
Over lunchtime I found it took more effort to get up to 30mph and maintain it. Wasn't doing that this morning. What could it be and why?
Old Feb 4, 2019 | 02:46 PM
simonsi's Avatar
simonsi
Could be as simple as the e-brake partly applied?
Really need more info.
Does it idle ok?
Does it rev freely in neutral (say to 2-3k rpm)
Same in all gears?
Sluggish in reverse?
No warning lights or MIL lit or flashing?
Engine running smoothly (but sluggish), or hesitating/missing?
Old Feb 4, 2019 | 02:59 PM
yardbird's Avatar
yardbird
If it's like a good majority of 3.0 Escapes, one, or both, of your front cats have broken up and plugged up the rear cat. Use a vacuum gauge to vacuum at idle and appx 2000-2500 rpm. Vacuum will either be low, or will start out somewhat normal and then steadily drop.
If the problem is the cats and you continue to drive it, you will eventually pop the end of the EGR valve off. You will then hear air rushing and gain some power back.
Old Feb 4, 2019 | 03:39 PM
hg3300's Avatar
hg3300
Does it idle ok?
Same in all gears?
seems to idle fine. Haven't checked neutral. Doesn't move unless I hit the gas. Engine isn't missing, just need higher rpms to get it to go.
I do have a code for the bank 1 cat and It's been like that for months.
Old Feb 4, 2019 | 03:40 PM
hg3300's Avatar
hg3300
my bank 1 cat set off the cel. I still seem to be able to accelerate unlike the time when I had to replace the rear cat.
Old Feb 4, 2019 | 08:00 PM
simonsi's Avatar
simonsi
If the car doesnt move at idle in D then I’d look for a binding brake.
Old Feb 4, 2019 | 08:02 PM
hg3300's Avatar
hg3300
Seems to be a likely culprit but intermittent. The drive home was fine. Just had an issue during lunch. What can I do to prevent this?
Old Feb 4, 2019 | 09:34 PM
simonsi's Avatar
simonsi
First find which brake(s) and binding, drivr home normally, when you get there feel the wheels and ser if one is hotter than its opposite side...once you find it you’ll need a physical inspection to see why it is binding, could be a sticking piston or sticking caliper, misadjusted cable or sticking wheel cylinder etc.
Old Feb 10, 2019 | 06:57 PM
Dadrider's Avatar
Dadrider
Trailering
Find the wheel that is hotter than the other side. As stated above, a sticking caliper or a front brake hose. When they fail, they constrict, and let the fluid return from the caliper to the master cylinder very very slowly then they almost hold the fluid and pads against the rotor as they get hotter.
My 2011 did that.
Dadrider.
Sais13579
Oct 24, 2024 04:22 PM
HuntingRat
24
Dec 1, 2017 12:22 PM
80skeys
May 27, 2010 10:06 PM
Cruiseomatic
34
Feb 7, 2007 03:48 PM
Big350
1978 - 1996 Big Bronco
Jan 23, 2004 11:02 AM
