While 4 threads per plug hole isn't ideal, the real issue was the ridiculously light factory torque spec. A member here tested with an old, junked head and was able to get the plug to around 80 ft/lbs before the plug itself broke, not the threads. Conventional wisdom around these parts is to use a tiny dab of silver anti-seize and torque down to about 23 ft/lbs. No more plug ejection after that.
Back to the OP's found plug: that looks like a CTA plug repair kit. That kit doesn't use an insert with a shoulder that really seats against the head. HOPEFULLY it just backed itself out and didn't damage the threads. You may be able to work a new Time-Sert in there, but I wouldn't be 100% certain it won't fail again having another repair already back out.
Great Point! Wonder if the threads are ok in the head and it just backed out? The threads on the insert look ok.
My Time-Sert kit will be here tomorrow. I'm gonna go ahead and ream and tap the correct way, then intall the Time Sert insert. Will let you know how it turns out..Thanks!
The failed insert has knurls at the top edge. The method of installation used on that insert type is to hammer a wedge into the insert to spread it out and dig the knurls into the head to hold it in. When I researched this job to do it on my own vehicle, I immediately excluded this type of insert.
A TimeSert installation uses red LocTite to stick it in place and it has a lip at the top edge of the insert to seat it against the head so it can't be turned in too far. The TimeSert insert is also spread apart to wedge it into the head as it is screwed in.
With the TimeSert kit the insert is better designed, the tools are much higher quality, and the kit includes cutting oil and LocTite plus a laminated instruction sheet.
CalVan is a quality kit as well, but is not as nice as the TimeSert.
You might try advertising on Craigslist or FB Marketplace in your local area to see if someone has a TimeSert kit they will loan you. Play up the angle that it is for a church van and you may find someone that will cut you a good deal.
Not trying to scare you but had same issue with a heli coil years ago. Plug fouled out with a bad miss but I kept driving it on a trip. When back home plug came out with coil stuck to it. Did a Bigsert insert to repair but still had a miss. Pulled head and had a bent valve which probably happened during first repair but the cylinder from running a couple hundred miles with plug not firing needed to be scuffed up. Good part is the Bigsert is still in and doing good. Good luck.
You will be fine will the time set kit. It's the only kit to use, I don't mess around with junk heli coil inserts. Make sure you use a bottle brush or a bore brush and clean with MEK or Acetone and let dry before applying the loctite.
.... A TimeSert installation uses red LocTite to stick it in place and it has a lip at the top edge of the insert to seat it against the head so it can't be turned in too far. The TimeSert insert is also spread apart to wedge it into the head as it is screwed in. .... .
I used the TimeSert kit to repair #3 on our 6.8l and have 24k on it with no issues.
I thought the "lip" on the insert was actually a seat. The tap cuts threads and a seat for the insert. The insert is then torqued in like the plugs to 25ft/lbs.
There is a knub on the insert threads that another tool, which looks like a tap, pushes out into the heads cut in the head providing a bit of a mechanical lock.
Timesert kit came in today. Successfully installed the #8 insert according to instructions. Scary putting those shavings down the cylinder. I blew out/ vacuumed best I could. Hope if there were any remnants, They went out the exhaust.
Thanks for all the tips from everyone!
Test drive went ok. Now to figure out why there is a short rotational squeak/whistle after shutdown. Always something!
You are supposed to grease the drill bit and tap. Go slow and constantly extract and apply new grease. It will prevent the majority of chips going down.
