Carburetor Choke Cable Install Problem
Old Feb 2, 2019 | 09:58 PM
hangontight's Avatar
hangontight
So, in the process of putting my '49 F1 back together, it appears I have come to an issue with the way the choke cable attaches to the carburetor. Below is a picture of my carb:
Below is a picture that I found somewhere on the internet of what I believe is the correct setup for a 49 flathead V8:
Look like I possibly have the wrong arm installed on the carb and am missing the bracket to hold the cable sheathing. Not sure how this happened unless the guy who rebuilt my carb put the wrong parts back on mine by mistake. Is there a place I could acquire the correct parts?
Old Feb 2, 2019 | 10:54 PM
EchoRadarFoxtrot's Avatar
EchoRadarFoxtrot
Hey there, I like your username! Very fitting.
You will definitely need a bracket to hold the choke cable sheath.
Also, yes the arm that actuates the choke should probably have an end like the one you showed in your second picture.
Your carb may not have been a "primary carburetor" and the type of arm on this is just to synchronize it with another on a dual or triple setup.
Often times on ebay you can find a junked up carburetor for parts and use what you need to make yours right... but your best bet might just be to ask your carb rebuilder if he has that part.
Old Feb 2, 2019 | 11:19 PM
bmoran4's Avatar
bmoran4
Parts Nerd Extraordinaire
Take a look at all the different carb types:
https://www.ford-trucks.com/forums/1...l#post18429371
I think this is the difference you are experiencing:
Old Feb 3, 2019 | 04:50 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Pic at upper left, 9700 is the choke cable.
Old Feb 3, 2019 | 08:15 AM
hangontight
thanks the help. I will have to order the correct parts, but it looks like a simple fix.
carsofchaos
May 12, 2026 08:19 PM
itsfordornothing
Jul 10, 2018 07:58 PM
Yogi-96blazer
Mar 2, 2006 07:37 PM
GregTruck
May 17, 2005 11:43 AM
