Brake light keeps coming on, pedal drops a bit
Old 02-01-2019, 08:08 AM
El Caballo's Avatar
El Caballo
El Caballo is offline
Well, my brake lights keep coming on and my brake pedal has some play up and down. I’m guessing that my master cylinder is starting to go. But isn’t there some return spring up there at the pedal pivot point?
I have only had it for about a month now and I’m still getting used to having manual brakes after about a twenty year hiatus from them. Still plenty of pedal feedback, but I’m taking this as a warning sign.
Old 02-02-2019, 12:38 PM
67xr7kat's Avatar
67xr7kat
67xr7kat is offline
Re: Brake lights ...
Lubricate the pedal pivot under the dash and check the nylon end bushings for wear
Old 02-02-2019, 01:43 PM
Blue and White's Avatar
Blue and White
Blue and White is offline
The brake light switch should be adjustable. Usually you pull the wire and screw it in or out to get it right then re-install the wire.
Old 02-02-2019, 04:21 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
If the brake light that keeps coming on...is on the dash, it's controlled by this: The Brake Pressure Differential Valve Warning Lamp Switch that threads into the Brake Pressure Differential Valve.
When the brake fluid in the master cylinders reservoir is low, this light comes on and stays on.
The switch is the same 1968/79 (C8AZ-2B264-A), but what year/series is the truck?
Old 02-03-2019, 07:44 AM
El Caballo's Avatar
El Caballo
I should clarify, it is the tail light brake lights that keep coming on. I have a 1978 F100 2wd 302
Old 02-03-2019, 11:59 AM
NumberDummy
Brake (stop) lamp switch threads into an adapter that clips onto the brake pedal.
If the brake lights keep coming on, the switch is out of adjustment, or one or more of the prongs that retains the adapter to the pedal broke, a common occurrence.
"Newer" replacement switch uses nuts to retain it to the pedal, eliminating the pesky adapter.
Old 02-03-2019, 04:24 PM
El Caballo's Avatar
El Caballo
The one in there was held in with a zip tie. :-/
Thank you Number Dummy.
Old 03-06-2019, 02:19 PM
RustyTank's Avatar
RustyTank
RustyTank is offline
Same sort of thing was happening to me recently. I picked up up a new brake light switch, looks to be the same kind as the old one but the new switch has the nuts as NumberDummy mentioned. Fixed the problem, brakes actually turn off now when I let my foot off the brake.
tndallas
09-15-2015 08:14 AM
WyoFlyFisher
12-14-2011 10:25 PM
PRIZMBLUE
03-06-2011 05:52 PM
andrewasl
08-18-2005 12:08 PM
96limited
01-24-2001 08:35 PM
Quick Reply: Brake light keeps coming on, pedal drops a bit
