Adding another 02 sensor on OBD1
Old Jan 31, 2019 | 09:39 PM
Dylan Mclain's Avatar
Dylan Mclain
I have built my engine and about to put it back in and I will be running true duels. Is there any way that i can add another 02 sensor and not trip the ECU or anything, I dont want to delete it or put a simm on it and I also dont think it's a good idea to run the sensor on just one side because I cant put the stock pipes that are together in one spot for the sensor on the new headers. Can anybody help with this one?
Old Feb 2, 2019 | 12:45 PM
Conanski's Avatar
Conanski
What is your truck?
You don't need a second O2 sensor and adding one won't help, just put a single sensor back into the passenger side header collector. Yes it is OK for it to only "see" one side of the motor, I had longtubes on my '90 and it ran perfectly with a single sensor for many years, I verified this with my tuner.
Old Feb 3, 2019 | 11:02 AM
Dylan Mclain
It's a 92 f150 with the 351w.
Old Feb 4, 2019 | 10:37 PM
Conanski's Avatar
Conanski
Yep you are good. That EFI system uses 2 batches of injectors.. 2 left bank and 2 right bank injectors in each batch but there is only 1 fuel map for all of them so it really doesn't matter how many cylinders the O2 sees.. all get the same injector duty cycle.
Rumble phish
2004 - 2008 F150
17
Dec 20, 2018 09:09 AM
Jnowaczyk
Modular V10 (6.8l)
Nov 6, 2013 01:02 PM
mikerans
18
Mar 20, 2013 01:00 PM
foxykool
Exhaust Systems
Jan 4, 2010 11:24 AM
winfordr
Jul 10, 2002 05:56 AM
