Two tone Paint Job
Old Sep 29, 2003 | 01:53 PM
reevoj's Avatar
reevoj
Two tone Paint Job
Hi, I have a 1999 F-150 Lariat, Two tone Black and gold, I was wondering what the dealer would charge to repaint the existing colors or paint the black with grey. But the question is are there other places that might do the same job quality wise?? Also what prices are reasonable?
Old Sep 29, 2003 | 07:19 PM
Aekisu's Avatar
Aekisu
<cr>
There are too many variables to give you an accurate cost. Some them include:
<ul>
The area you live in.
The amount of bodywork required.
The type of paint (acrylic enamel and urethane being the main ones)
What kind of results you are expecting
</ul>
If you came to me and it was a simple scuff and shoot (no bodywork and the old paint was not being stripped off), you could expect to pay $500. That price does not include the cost of materials. If you wanted it colorsanded and buffed, add another $300.
Your paint costs depend on what you want and the quality of the product. For example, clearcoat can run you $75 - $170/gallon.
You need to decide what you want and then start pricing your area. I think you are going to find a paint job is an expensive item, if you are expecting top quality work. If you need help in choosing what you want, we can help you in that area.
Old Oct 7, 2003 | 05:29 AM
capt caper's Avatar
capt caper
I have an 02 SD in Touradour Red Metallic. I'd like to make it two tone in the silver Ford uses myself. I have expierence spraying but not much with car paint.
I believe the truck is base/clear coat. Can I use a two part metallic over the clear coat? Or do I need a sealer to protect the clear coat from a reaction?
I was hopeing just to scuff and shoot, since the paint is like new.
Capt.
Old Oct 7, 2003 | 02:08 PM
Aekisu's Avatar
Aekisu
<cr>
If indeed it is a bc/cc urethane paint job, you don't need a sealer. Scuff and paint. 400 grit for a solid paint. 600 grit for metallics.
Be careful about cut-thrus where the base is exposed. The base could lift when exposed to the solvents of your new paint. If this does occur, normally I just touch up the area with some clear (allowing it to set up good) before I shoot the base. Clear is an excellent sealer.
Old Oct 7, 2003 | 05:32 PM
capt caper's Avatar
capt caper
Thanks......
Do you know the paint number for the silver that Ford uses for the two tone on these Super Duty's? I belive they use the same silver on all and same with the beige, which I had before.
Capt.
sled250
Jun 5, 2011 12:06 AM
v8xploder
Paint & Bodywork
Apr 2, 2011 08:50 PM
JMILLE3
19
Sep 26, 2009 09:16 PM
newmanator
Paint & Bodywork
Jul 2, 2007 12:44 PM
DukeXLT
1978 - 1996 Big Bronco
Jul 21, 2003 05:53 PM
