67 F250 brake lines
67 F250 brake lines
Hey folks,
Looking for a little help with pre-bent brake lines. I've found a couple sources for these, but it seems like they all go up to '66 or start at '68
I have an '67 F250 4wd application with original drums all around and I'm looking to redo all the brake lines.
Please hold off on the conversion to disc brakes. I'd much rather work on disc brakes, but it's not in the budget and I'm trying to keep the truck as close to stock as possible.
I know that the 67 has some odd ball things in it. Just wondering what others experience is with the brake lines.
Also, I have the same question for the pressure differential valve. I'd like to pull that apart and clean it up, but I'm not sure where to get the o rings.
As always, your expert opinions are greatly appreciated. Thanks in advance.
Jeff
Jeff
Tedster9- thanks for the suggestion on the brake line. I dont mind fabbing the shorter lines. I was really hoping the pre-bent long ones would fit.
mrp- thanks for the heads up. I didn't realize it would be that had to take apart. Its sitting in brake fluid, how stuck could it be. Appreciate the reality check.
I got the idea online some place, maybe here and a search might pull it up.
I went to NAPA and got some fittings to connect them. One end was a brake fitting, attached to some brake line - I used the end of one of my old brake lines since I was making new ones anyways. I don't remember exactly what the other end was, maybe an AN fitting...its been a while. The counter man at the parts store helped me find the pieces that made it work. I just took the gun and the brake line to the store. It screwed on to the grease gun and it pushed out the plunger easy.
You have to make sure to clean the valve out really well afterwards, petroleum products and brake components do not mix well.
As far as pre-bent lines go 67 to 72 F250 4WD are the same. I could not find a source for a kit. I understand your desire to keep it stock. What axle do you have in your truck Jeff? I happen to have a set of Flexible front lines and the knuckle seals for the 44HD axle found in the 67-72 F250's. Let me know if you need these, I am never going to use them.
Hey folks,
Jeff
Jeff
Geez, ultraranger, you do beautiful work. It seems every post I've seen of yours where you've made something, it comes out perfect. How about making something ugly for a change. When ever I bend brake lines, it looks like a 3 year old put it together... blind folded.
Nobody ever showed me how to bend or flare tubing. It's just something I picked up on my own by fooling with it and anybody with a little bit of mechanical aptitude can do it too.
