Steering Gear Differences
Old Jan 30, 2019 | 09:31 PM
Otterby's Avatar
Otterby
I pulled the steering box out of my ‘59 F250 4x4 and it’s pretty loose. The casting number on the box is 4CC39. I have a good box out of a ‘58 F350 2wd that’s has a casting number 4CC25. I’ve read that the 4x4 box is different than the 2wd but they look identical. Does anyone know if I’m ok to use the ‘58 2wd box in the ‘59 4x4?
Old Jan 31, 2019 | 12:20 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
I have a good box out of a ‘58 F350 2wd that’s has a casting number 4CC25 (B7Y-3504-A). I’ve read that the 4x4 box is different than the 2wd but they look identical.
Not the same!
B9TT-3504-A .. Steering Gear Box (no housing casting number listed) / Obsolete
1959/60 F100/250 4WD
B7Y-3504-A .. Steering Gear Box - Housing casting number: 4CC25 / Obsolete
1957/58 F350/600 / 1959 F350 except with Saginaw steering box / 1959/60 F500/600 / 1960 F350.
F100/250 4WD uses the same steering shaft as F350 (B7Y-3524-A), but the 4WD's sector shaft (B7T-3575-C) is different than the F350 sector shaft (B7Y-3575-A).
The steering shaft bearings (2) and upper/lower cups (1 ea), sector shaft bushings (2) are the same for both.
All 1953/78 F350's are 2WD, 1979 was the first year that F350's were available with 4WD // If a 1953/78 F350 has 4WD, it's an aftermarket conversion.
Old Jan 31, 2019 | 01:14 PM
Otterby's Avatar
Otterby
Thanks again NumberDummy! So is it safe to say that if my pitman arm fits on the ‘58 2wd box I’m good to go?
Old Jan 31, 2019 | 01:57 PM
NumberDummy
The Pitman Arm attaches to the sector shaft, but as I said in post #2, the 4WD sector shaft is different than the F350.
Old Jan 31, 2019 | 09:16 PM
Otterby's Avatar
Otterby
So I measured everything up and the sector shaft is identical. However, the mounting plate is slightly different. One hole won’t line up. Nothing a drill can’t fix.
southern cad
May 8, 2017 10:25 AM
1964FORDTUF
Jun 29, 2015 02:15 PM
winginit
Nov 9, 2014 11:21 AM
jamhh
Apr 26, 2013 09:33 PM
zakt
Apr 7, 2013 10:58 PM
