ABS Unit Bleed... Which Software?
Old Nov 6, 2017 | 12:58 AM
beefey's Avatar
beefey
If the dealership the only ones that can modulate the ABS unit to push the air out of the system?
I had a line blow out and now I believe there may be air in the ABS pump... Any way to get the ABS unit to turn over? When the light is on it turns the ABS off so I can't stomp on them on a gravel road or anything.
I have ScanXL Pro, Forscan, and ScanTool. All of these I think cannot do it.
Thoughts?
Thanks!
Old Nov 6, 2017 | 03:33 PM
Stewart_H's Avatar
Stewart_H
Which line blew off?
Check your ABS sensors to make sure the line (if it disengaged down at the hub) didn't damage your ABS sensor.
https://www.ford-trucks.com/forums/1...l#post15895025
Click the link, scroll down to the brake section, and click the link for bleeding your brakes.
Stewart
kidzstang
1997 - 2003 F150
Feb 22, 2014 06:15 PM
71FoMoCo
1983 - 2012 Ranger & B-Series
Aug 25, 2010 04:13 PM
Nitramjr
Dec 15, 2007 10:33 PM
DougNC
Mar 4, 2007 02:14 PM
89MustangGX
Jun 10, 2004 12:03 AM
