Trim
Old Jan 26, 2019 | 07:21 PM
roadrunner doug's Avatar
roadrunner doug
Trim
I have a chance to buy all the side trim off an 79 100,)(both sides)and the tailgate trim,,whats a reasonable price..Looks good except needs cleaning and polishing..
Old Jan 27, 2019 | 12:29 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by roadrunner doug
I have a chance to buy all the side mouldings off an 79 F100 (both sides) and the tailgate trim. Whats a reasonable price? Looks good except needs cleaning and polishing..
Which type of moulding is it? There are 3 possible types. The narrow upper body side mouldings are not reproduced, the other types are.
Old Jan 27, 2019 | 06:22 AM
roadrunner doug
Its the trim that has the rubber in it and the marker lights.
Old Jan 27, 2019 | 07:22 AM
scottscott's Avatar
scottscott
It depends on if you need the trim or not.
I buy it at swap meets for $5 for each door or fender piece, $5 for a pair of cab corners, $10-15 for the bed. Narrow upper & lower tailgate, $5 each, FORD lettered trim panel $10-15, big upper panel $15-20. I won't pay more than that unless it is NOS, or absolutely mint, which is just about impossible to find anymore. If any of it is dented, bent, has holes drilled in it, or is scratched, it is scrap.
There are guys at the swaps that want 5 to 10 times the price I'll pay for the trim, they have been hauling it around for 15 years. Every time I see it it is in worse condition from loading & unloading, & is getting close to worthless.
I'll resell it to local guys, maybe I can get double what I pay for it.
Old Jan 27, 2019 | 07:35 AM
roadrunner doug
thanks,,he wanted 150 for all of it
Old Jan 27, 2019 | 08:34 AM
caravaggio2000's Avatar
caravaggio2000
A related question... is all the trim andonized aluminum or is that just the grille shell?
Old Jan 27, 2019 | 08:39 AM
scottscott's Avatar
scottscott
All the exterior trim is anodized aluminum.
Old Jan 27, 2019 | 09:06 AM
caravaggio2000
Including the tie down hooks and lower side moulding? I thought maybe those were different.
I know some people do the oven cleaner or drano trick to deandonize these, but has anyone priced out what it costs to get it all refinished professionally? One day I'm going to get my truck painted and I'm a little worried getting the trim redone is going to cost me more than the paint.
Old Jan 27, 2019 | 09:57 AM
scottscott's Avatar
scottscott
Tie down hooks are not, they are chromed die cast pot metal. Lower side molding is anodized aluminum.
I've tried the oven cleaner trick with poor results. Some spots it removes the anodize quickly, other spots it does not touch. When you hit it with more cleaner to remove the stubborn spots the cleaner eats in to the aluminum where the anodize was already removed, causing deep pits. This pretty much ruins the part.
I bought a lot of used pieces to get the nice stuff I used on my truck. It took a lot of searching, but I found what i wanted, no refinishing needed.
Old Jan 27, 2019 | 05:51 PM
lafermedavid's Avatar
lafermedavid
I know its expensive but how does original compare with Carpenters trim,,,,,,,,is it like everything else its not original?
lafermedavid
Aug 21, 2014 09:21 PM
86'F-150
Apr 22, 2013 07:27 PM
460F150
Mar 28, 2009 01:32 PM
nobodyspecial
Dec 19, 2006 10:24 PM
