1994 F-250: Mushy Brake Pedal w/ Engine Running
Hey Guys,
Now that we've finally had a break in the weather I finally got around to working on the truck again (1994 F-250, 5.0, RWD). I have replaced the brake shoes, all the drum brake hardware, the wheel cylinders, the calipers, and today I replaced the master cylinder. With the help of my neighbor, we bled the brakes starting from passengers rear, drivers rear, the RABS, passenger front, and ending with the drivers front.
With the truck off, the pedal feels firm. As soon as the truck is started the pedal will go all the way to the floor and you can hear a whooshing noise when you depress the pedal. When you turn the truck off, the pedal goes back to firm. The truck stops but it's disconcerting having the pedal go all the way to floor with almost zero resistance.
Could this be indicative of a failing booster or do we just need to bleed the brakes again?
I got the new booster installed today. The whooshing noise is gone and the brake pedal is much more firm but I'm still able to push the pedal to the floor. I noticed the rear line is leaking at the booster. The fitting is as tight as I get it so looks like I'll be ordering some new Nicopp line.
Just went thru this with my 94 f250. I ended up replacing all my metal lines, master cylinder, rubber lines and by passing the rabs. I would fix one line, think everything is great and it would even pump up when off but had such a slight leak some where else that it would eventually leak down while started.
Keep in mind the rear metal line going into the wheel cylinder is a 1/4 fitting on a 3/16 line. Orylies has a lot of break hardware compaired go other places. For the relatively cheap expense of metal line and a double flaring tool its actually worth doing them all. You can cheaply by pass the rabs real quick just to make sure thats not your problem before replacing all the lines.
Once I replaced all my lines and everything else I have solid breaks again. Hopefully you can sort it out. I had a super small leak at my master cylinder fitting too, front one and I had to really crank it to get a good seal.
Now that the weather turned, I finally had time to work on the brakes again. I bled the brakes again using a Motive Products power bleeder but the end result still was a mushy pedal. The truck will stop and the pedal is firm with the engine off, but it feels spongy with the engine running. I may end up running new hard lines as I am not sure what else could be causing the problem.
Your statement made me change my brake booster today. Wow, what a difference. I got the truck late last year and didn't know what the brakes should feel like. I bled them several times but no change. After getting the new brake booster in, they are much, much better. Thank you!
mckoloum
05-16-2019 03:53 PM
myfeetrock
01-22-2015 09:55 PM
granny_rocket
06-18-2014 07:57 AM
91dirtydiesel
56
01-23-2010 06:02 PM
