P0401 Error Code
Old Jan 26, 2019 | 11:33 AM
Stevem4134's Avatar
Stevem4134
P0401 Error Code
My 2011 6.7 F250 with Lariat trim has been throwing the P0401 error code lately. It comes on AFTER a regen. It can be reset and then it comes back after the next regen.
Any ideas as to what causes this and how to fix.
Old Jan 26, 2019 | 11:46 AM
kper05's Avatar
kper05
Your EGR cooler is close to plugged or has plugged. Soot from daily driving empty, stop/go traffic, etc. (other than working it hard all the time) is the cause.
I was quoted $900 for repair when mine failed last year. It does power derate. Mine would struggle to pull a hill with the tractor behind me. Clearing the code would only buy me a few miles most of the time.
If you're good at repairing modern diesels, KC8QVO did a write-up on this as an option. I think this project was his fourth EGR cooler.
https://www.ford-trucks.com/forums/1...l#post18018077
Old Jan 27, 2019 | 08:05 AM
Stevem4134's Avatar
Stevem4134
Thank you I'm not looking forward to that bill.
Old Jan 31, 2019 | 07:46 AM
Stevem4134's Avatar
Stevem4134
Anybody know why the light only comes on after a regen and not in between regens?
Old Jan 31, 2019 | 05:42 PM
kper05's Avatar
kper05
My guess is it isn't completely plugged vs mine would flag during normal driving. When an active regeneration is commanded, the actuator bypasses the EGR cooler to increase EGT to the DPF. Post AR, exhaust is then directed back through the EGR cooler. The ECM doesn't like the readings and flags the DTC.
Old Feb 1, 2019 | 06:59 AM
Stevem4134's Avatar
Stevem4134
kper05
Thanks, that's good information
Old May 10, 2019 | 08:33 AM
Stevem4134's Avatar
Stevem4134
Update:
The P0401 code comes and goes. After it comes in, I can immediately reset it. The activation of the code and resetting does not appear to be related to regeneration. I have seen the code come in any time (I have monitored it from 8 miles up to and past 350 miles) after the last reset. There is no pattern as to when it comes in. I have not noticed a change in the engine performance or mileage.
Is it harmful to continue to run the truck when it is acting like this?
Can a shop really troubleshoot and fix the issue with the code coming and going or should I wait until the code will not rest?
My truck threw this code when it had 44K miles. At that time, both the EGR valve and Cooler were replaced. My truck now has 82K miles on it. During the first time (at 44K) the dealer, first replaced the EGR valve. The code came back and they then replaced the cooler.
diesel stopper
6.7L Power Stroke Diesel
Mar 16, 2016 01:33 PM
EMC V10 X
Nov 19, 2014 05:19 PM
GSlahor
Jul 21, 2014 03:17 PM
dvrjump
Apr 12, 2014 12:57 PM
salty
May 16, 2009 06:24 AM
