Looking to see if anybody is interested in parting with a factory tach for a bullnose. My smoked! I know they are hard to find. Thanks. Already posted in marketplace, but thought I’d post here too.
There’s an excellent thread around about cleaning them - it may be in the stickies. Have you performed the other testing to verify the harness and printed circuit is good?
I also had a dead tach. I was looking at the RC page too but happened upon an 80 cluster in the JY for $40. Plugged it in and it actually had a working tach.
I do recall th the 80 (and maybe 81) have a different pin out at the harness plug, so swapping complete clusters with something later requires some reconfiguring, but I assume the tachs are all the same.
I accidentally crossed cables when trying to jump it!! I smoked only the radio,and clock(I thought) but found out today that the tach also met an untimely demise!!! Yes I’ve checked and they seem to be it! Truck starts and runs with no problems ........yet!!
I went to Car-Part.com--Used Auto Parts Market and plugged in your truck and pretended I was looking for a front fender in New Jersey. The following junkyards say they have a fender. Looks like about 5 or 6 yards MIGHT have one of these trucks in the yard, and one of those MIGHT have a tach. I think it would be worth calling and checking.1986
Fender Assembly
Ford Truck F150RH,Front,BLK000A
0A35927$CallHolladays Auto Parts USA-NJ(Salem) Request_Quote 1-856-935-0133 Request_Insurance_Quote 1821984
Fender Assembly
Ford Truck F350RH,Front,WHITE EXT, DENTED FRONT AND REAR, PAINT PEELING, NEEDS A LOT OF WORK4D2
6D2C
ccA69006$CallSouth State Auto Parts USA-NJ(Williamstown) Request_Quote 856-728-7766 Request_Insurance_Quote 2101984
Fender Assembly
Ford Bronco Full SizeRH,RED EXT,516R3.25C
3.2
ccA60088$CallSouth State Auto Parts USA-NJ(Williamstown) Request_Quote 856-728-7766 Request_Insurance_Quote 2101985
Fender Assembly
Ford Truck F250BLACK,2 Door,STD000A
0AA1336$100 actualGiancola Auto Wrecking USA-NJ(East-Brunswick) giancolaspots@gmail.com?subject=Car-...stal%20228 44 732-257-7556 / 732-257-74952571986
Fender Assembly
Ford Bronco000A
0BB0176$100 actualGiancola Auto Wrecking USA-NJ(East-Brunswick) giancolaspots@gmail.com?subject=Car-...Postal%2022844 732-257-7556 / 732-257-74952571980
Fender Assembly
Ford Truck F350000,2 DR,WHT000A
0Y-362$CallWarren Auto Wreckers-ELITE USA-NJ(Warren) Request_Quote 1-732-469-4216 Request_Insurance_Quote 2591986
Fender Assembly
Ford Truck 350@000A
0$CallR & S Recycling-ELITE USA-NJ(Paterson) timshaw@ymail.com?subject=Car-Part.c...Postal%2022844 1-973-942-2213
I had the same thing a few years ago while working on the timing............I temporarily connected an aftermarket tach under the hood to the coil, in reverse polarity, & it fried the truck tach (although the aftermarket one survived). Fortunately nothing else suffered.
Yes sir, this stuff is creeping up in price. I bought a whole 1984 tach cluster a little more than a year ago for $75 USD (Ebay) and right now, they're in the $120-$200 range on Ebay.
I very rarely ever see a Bullnose tach for sale all by itself...it's usually the whole cluster or nothing at all. A tach was a rare option around here...I haven't found one in an old Bullnose yet, and I've looked at dozens of them.
I recently grabbed a mint gas cluster (w/4500 RPM tach) from a junked 1985 F800 Fire Truck. I didn't actually need the thing for anything other than a possible future 300/6 project.
Thank you Franklin2 !!!!! Found a complete cluster and clock out of an 80 bronco at a yard about a 1/2 hour away from me. They said it just came in. I guess I just lucked out. Picking everything up on Tuesday $50!!!!
just take yours out then apart and clean all the old brown glue off and put back in 9 out 10 that's why it has quit working,, could also be a dark yellow glue look.. not making a good connection ,,be careful of the needle though no need to take it off though ,,takes about 30 min to do.. brown glue easy to do the yellow look a little harder, just use rubbing alcohol and a Qtip and scape it off.. also check your green wire off the dizzy to see if it has came loose or if your circuit board has a burn spot on it ,,I wouldn't just go and buy one yet till I did these thing's but i'm betting cleaning it will work..i take bad ones that some think are and fix them that way and BAM I have another that's good to go..
