Tracking Down Electrical Woes
What works:
Starting System
Horn
Turn Signals
Brake Lights
Running lamps/Headlights
Dome lamp
Hazard Lamps
Reverse Lamps
What doesn't work
Windsheild wipers
Washer Pump
Radio
Dashboard lights
Weirder, the blower switch does not work, but if you move the HVAC/mode control to the right, it starts blowing - the more it goes to the right the faster it goes.
What I don't understand is that some of these (Radio, Dash Lights) do not have power at the fuse block even with the key in run position.
Any tips suggestions appreciated. I wish I had not almost completely assembled the dash before testing these things - I am worried a lot us going to have to come out again.
Thanks
Would there be a separate fusible link for the nonworking items on that truck?
If I remember correctly, you can pull the fuse box out to check it, without too much trouble.
And all of the nonworking items are exclusively in-the-cab accessories, whereas the working items are all completely outside the cab. That could be a clue.
