Dana 61 replacement
Old Jan 23, 2019 | 11:12 AM
Palmy's Avatar
Palmy
Dana 61 replacement
So I have a 76 F-250 2wd camper special. It has a super popular dana 61 with 3.07 gearing. The carrier bearings are completely destroyed and the gears aren't far behind. I am thinking of replacing this axle with a dana 60 or dana 70. Does anyone have suggestions on which year / model I should be looking for? I would like one that is as close to being compatible as possible. Thanks in advance.
Old Jan 23, 2019 | 05:21 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Dana 60/61: The carrier bearings are the same as are the spider gears. There are two different types of axle (differential) gears, so they may be the same, may not be.
If you want to keep the 3.07 ratio, fix what you have. 60 wasn't available with 3.07 and finding a Dana 60 with a 3.54 "high speed" axle ratio will be difficult.
Dana 70's only installed in F350's, 1973/79 available ratios: 3.73 - 4.10 - 4.56 - 4.88.
Buying a used axle: It might not be any better than what you have now, could be worse.
smle
Sep 10, 2017 06:54 PM
pm042070
Nov 6, 2014 09:44 PM
jrodimus
Apr 3, 2010 07:52 PM
sparky69
Offroad & 4x4
Dec 26, 2005 07:23 PM
