The inner fender wells are galvanized..just think if they would have galvanized the cab! - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1973 - 1979 F-100 & Larger F-Series Trucks
Reload this Page >
Old 01-21-2019, 05:32 PM
niko20's Avatar
niko20
niko20 is offline
niko20 is starting off with a positive reputation.
I guess maybe it would have been too expensive? Can you imagine if Ford would have also galvanized the cab too? We'd have pristine Ford trucks to this day
Old 01-21-2019, 06:42 PM
reecieboy's Avatar
reecieboy
reecieboy is offline
reecieboy is starting off with a positive reputation.
I thought the cabs were galved.
Mine certainly looks like it....... where it hasn't rusted out.
Old 01-21-2019, 10:15 PM
nzirbel
nzirbel is online now
nzirbel has a good reputation on FTE.nzirbel has a good reputation on FTE.
I read an article somewhere saying that automakers were forced to use certain standards of corrosion protection in the 70s, and some have attributed that to why they are generally in better condition for their age compared to later model vehicles. Wish I would have bookmarked it!
Old 01-22-2019, 02:49 AM
77&79F250's Avatar
77&79F250
77&79F250 is offline
Used OEM parts guy
77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.
I believe the cowl panel IS galvanized and there for hard to paint or needs some special mix to get it to stick.
Old 01-22-2019, 03:45 AM
1TonBasecamp
1TonBasecamp is offline
1TonBasecamp is gaining momentum as a positive member of FTE.
When the floors rust out on old Broncos (on a far too regular basis) they can rot off completely and the support channels under the floor are often still pristine. Guess they were not worried about the floor so much, but figured it was worth a few extra cents to protect the supports.
Paul
Old 01-22-2019, 05:06 PM
scottscott
scottscott is online now
scottscott has a good reputation on FTE.scottscott has a good reputation on FTE.
From the 1977 truck brochure.
Old 01-22-2019, 06:21 PM
tbear853's Avatar
tbear853
tbear853 is offline
tbear853 has a very good reputation on FTE.tbear853 has a very good reputation on FTE.tbear853 has a very good reputation on FTE.
I know about front fender liners, but have never seen OEM rear fender "liners" like the plastic front ones. I do have new aftermarket ones in basement.
Old 01-22-2019, 06:55 PM
1TonBasecamp
My '79 had front and rear plastic liners. Kind of a pain in some ways, but I like having anything in there that keeps at least some of the junk at bay.
Good to see they galvanized the cowl vent area! No wonder that minimal amount of paint in there was still able to keep mine from rusting under all the leaves. Probably not enough for salty, or just really wet areas, but for around here it seems to be holding up.
I just saw another member's truck the other day and the PO had cut out holes on each end of the cowl, under the hood in the corner (basically where the RED area is on that drawing) for great access to cleaning out the cowl. Looks like it would be super easy to make some covers that you could take off whenever you needed to clean it out. I started a thread a few months ago to see what others had done to keep the cowl clean, but this was one of those fixes that looks like it could actually work and not mess up the visual aspects above the hood.
Paul
Old 01-22-2019, 07:02 PM
77&79F250's Avatar
77&79F250
Used OEM parts guy
AFAIK They do not make OEM rear fender "liners" like the front. Just two plastic splash shields for the rear. One each side of the middle fenderwell lip part that always causes the bed lip to rust out. I seen a guy on here take a front set and MAKE on the rear. Damn smart idea.
Edit: Just read Paul's post again..I'd like to see a pic of them liners.
Old 01-22-2019, 07:47 PM
fordguy2100's Avatar
fordguy2100
fordguy2100 is online now
fordguy2100 has a good reputation on FTE.fordguy2100 has a good reputation on FTE.
The guy I visited that had 2000+ vehicles in the woods had quite a few dent sides with liners front and rear... was thinking they'd be nice to have. If they are hard to find maybe I outta go grab a few sets lol
Old 01-22-2019, 08:05 PM
Charles Howard
Charles Howard is offline
Charles Howard is starting off with a positive reputation.
Do you want a picture of the one that rusted off with the fender support or the one still attached to the truck ;P ? A bunch of mud and rocks got stuck where it meets the fender on my truck and caused the fender support to detach
Old 01-23-2019, 07:15 AM
somethingclever's Avatar
somethingclever
somethingclever is online now
somethingclever has a great reputation on FTE.somethingclever has a great reputation on FTE.somethingclever has a great reputation on FTE.somethingclever has a great reputation on FTE.somethingclever has a great reputation on FTE.
I had a 77 with rear plastic shields. They were not full liners like the front.
cool pic Scott....thanks for sharing.
Old 01-23-2019, 04:25 PM
reecieboy's Avatar
reecieboy
That makes sense.
Pity no-one presses a replacement roof panel and Z channels.
Old 01-23-2019, 04:37 PM
myrtlehead
myrtlehead is offline
myrtlehead is starting off with a positive reputation.
Buddy came by my house a couple days ago crying how they are repoping/remaking 66-77 bronco bodies and how his is not going to be worth as much, blah, blah, blah. I was just thinking they better coat them bodies with some thing that can fight rust this time around.
Old 01-23-2019, 10:36 PM
meangreen92's Avatar
meangreen92
meangreen92 is offline
meangreen92 has a very good reputation on FTE.meangreen92 has a very good reputation on FTE.meangreen92 has a very good reputation on FTE.meangreen92 has a very good reputation on FTE.
You can tell the galvanized areas by the way paint chips/flakes off, and how the metal still stays clean for quite a while, where untreated metal would immediately flash over with rust.
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
