P0175 Code - Click sound then OK???
Old Jan 23, 2019 | 08:59 AM
batwagon's Avatar
batwagon
Hey, I hope you all can help me out with a problem I can't seem to track down. My 2003 V10 Excursion throws P0175 (Bank 2 Too Rich), P0304 (Cyl 4 Misfire), P0308 (Cyl 8 Misfire), P0316 (Misfire on first 1000 Revs). The LT Fuel Trim 2 is -25%.
When I start up cold it's OK for a few minutes but when I press the pedal nothing happens and the truck massively boggs down. It will go about 15 MPH with pedal depressed then I hear an audible "Click" noise and the truck takes off like a bat out of hell.
When Im at highway speed all is OK but when I pull off to a stop the same thing happens.
Anyone know what that "Click" could be?? EGR, Evap Solenoid? Anyone know which one of those has a loud click when activated after being stuck open?
Sounds like a vacuum leak but I have checked all vac connections including the PCV and brake booster lines and can't find a leak in the hoses.
Thanks
71sportcustom460
Dec 4, 2015 12:23 PM
mstng_ray
1983 - 2012 Ranger & B-Series
Sep 20, 2006 10:17 PM
nucleartruck
Jun 17, 2005 09:16 AM
MatthewC
1978 - 1996 Big Bronco
Jul 30, 2004 09:07 PM
nickmobile67
33
Jun 28, 2004 09:32 PM
