Sponsored by: Kumho
Spring Question
Old Sep 29, 2003 | 06:18 AM
jbrdrummer's Avatar
jbrdrummer
Spring Question
Folks,
I am kinda confused here...OK, I am second generation owner of my '90 150, 4x4, w/302...the rear sits 4" higher than the front, now it appears as though the original owner put a helper spring in the rear with what looks to be about a 2" block...I am assuming the front end is stock, so here-in lays the question...to level the front vs. the back, what size leveler spring should I be looking nto? From what I understand, the advertised height on aftermarket springs is that over stock...correct? So getting, say, a 1-2" leveling spring really isn't going to level it out...or am I just not seeing the forest for the trees...
Thanx
J.
Old Sep 29, 2003 | 02:00 PM
MustangGT221's Avatar
MustangGT221
Well the rear end has 2" blocks stock. It's suppose to be a 2" difference from front to rear. So it seems like your rear end has been raised about 2". What do you want the stance to be like, level? 2" difference?
Old Sep 30, 2003 | 06:17 AM
jbrdrummer's Avatar
jbrdrummer
Mustang - Well, i would like a little more level stance, I understand I won't get it exact without putting an entire lift kit under her...I am happy with the lift in the back, it's enough for my old butt, just wanna get rid of the sissy sag in the front. I am a bit hesitant to go with a 4" spring up front as I am afraid that will be "to much"...I think a 2" leveler from Rancho or SkyJacker would be about right...a slight rake, but still "up there" as it were. Thoughts?
J.
Old Sep 30, 2003 | 10:47 PM
natewoz's Avatar
natewoz
If you go any taller than 2", you're looking at lift kit brackets and all the other goodies. It'll cost 1/4 the price to go with 2" over 4".
dmueller71
Mar 4, 2015 10:29 AM
LCrowe2012
Feb 25, 2014 01:59 AM
DieselDreamer
Modular V10 (6.8l)
16
Feb 17, 2012 04:22 PM
excalibur3000
May 15, 2008 09:20 AM
nskitts
Aug 19, 2007 12:26 AM
