6.9 idi glow plug and fss wiring help needed
On a 1984 f350 with a 6.9 idi which wire powers the glow plug solenoid and which one sends power to the fss. Im having a really hard time figuring it out. i thought the purple wire powered the glow plug solenoid but when i put power to the fss the solenoid clicked. So now im really lost i have no idea what powers either one.
by https://www.flickr.com/photos/150153850@N07/, on Flickr
Heres what i got
Heres what i got
The purple wire is the right wire to trip the glowplug solenoid. It is powered by the controller (long thing standing up behind your driverside cylinder head) you can apply power to that terminal for 5-10 seconds depending on the temp and if the plugs are good and the fss is getting power it should crank.
Not sure what your problem is here. Guessing it won't start so you may have to make your you have over 1/4 tank of fuel and push the valve on the fuel filter housing to make sure you don't have air in the system. You'll have to push it down while someone else cranks it.
garrettsr5
04-08-2013 11:11 PM
travis77365
05-22-2005 01:50 AM
