1951 Ford f1 Build
1951 Ford f1 Build
Just picked up this 1951 Ford F1 basket case! done a bit of work on it so far but here's the progress!
It's going to have a flat bed made to fit 2 motorcycles side by side, the motor i will put in it is an '06 LQ4 or maybe an LM7 i have laying around. I've got fantasies of a turbo... Going to build a box tube frame with '89 corvette suspension up front and a ford 9" in the rear with a triangulated 4 link set up. not sure which trans will go in it yet, but i'll let my available funds decide that later haha.
The Rear wheels on the Ford were locking up the whole way home! haha
Managed to get it in the garage with about 6 people as the rear wheels would not let go!
and begins the strip tease...
Made a wooden frame to support the cab by the corners
as to be expected the corners are all rotted out
inner structure for the driver's side corner and body mounts all formed
Passengers side welded in. I was a bit smarter with weld placement and warpage was much more manageable
Received 1,353 Likes
on
Thank you! Yes these parts are all made from scratch. The frame is going to be a box tube frame, nothing too crazy, but made to fit the cab with corvette suspension and i want the running boards to sit 4" off the ground so the frame will be notched to set the ride height. The visor is a must have!
The Corvette suspension is 60" hub to hub which is exactly the same hub to hub dimension as the original front end. I wont run into this issue here with the '51
Update #3
Made a bit more progress on the rear of the cab. Floor is coming soon! (that back section of the cab will get fixed once it is mounted to the frame)
The back section was coated with tar or something from the previous owner and will get replaced after the cab is mounted to the frame! Or maybe after it's running...
Thank you, greg! You gotta have atleast one (or two or three) mills in the shop! The white one is a pc based cnc and then the trusty ol bridgport.
