Had RAVELCO Installed
Traveling to Tucson from Gulf Shores we planned to have a RAVELCO Anti-theft Device installed while staying a couple days near San Antonio, TX. Installer came out to the campground. Install took a couple hours. I watched while he did it and when it was all done I was very impressed. I defy anyone to find and defeat this device in under a day. You would literally need lots of time and tools (multimeter) and a fair amount of Ford SD electrical wiring knowledge to figure out how/where its installed and then defeat it. Car thief isn't gonna make it happen in some parking lot or driveway. I laughed when he told me how many times he has had to go to dealerships to show techs how to remove systems from used vehicles that customers were buying and didn't want to keep RAVELCO with vehicle (not sure why you wouldn't want to leave it in) . Anyway, very professionally done and I have the piece of mind knowing that regardless if some thief breaks a window to get in my truck, the truck will still be there even if my loose change isn't!
Engine compartment photo after install....you won't see a hint of the device wiring.
Doesn't affect the remote start at all. If you don't have the Ravelco plug in however the truck won't start no matter what. Installer showed me how easy these trucks are to break into and hot wire. The remote start and keyless start vehicles are even easier.
Since you watched, is this the type of aftermarket installation that relies on scotchlok type connectors seen on so many car alarm installs?
Having been in the automotive field in a prior career (new cars) I came to despise those cheater items.
Never had aftermarket alarms and such and never worried as well where we live.
But, next year will be a new truck and now retired, hopefully a warmer retirement friendly but unknown locale.
No Scotchlok connectors used. Only spliced into two wires that control fuel pump and starter. He used heat shrink butt connectors and then taped all splices before putting inside plastic wire conduit. He covered the only part of the wire conduit visible with factory OEM electrical tape so you couldnt see a difference in the tape. Half the skill/art/value of the install is the how well the installer camouflages or hides his work.
Im sure different installers will have different procedures, but knowing it can/should be done properly is a plus.
retired?
i just retired from fire. Will be spending part of my first winter away in Gulf Shores.
Yup...full timing in the fifth wheel and loving it. Gulf Shores was nice but they get a buttload of rain. Lookin for a little drier area. Park we were in for a couple months was almost all snowbirds from Michigan, Wisconsin, and Indiana.
