86 E150 Died on freeway
Old Jan 17, 2019 | 11:24 PM
Chrystine Gimeno's Avatar
Chrystine Gimeno
On my way to Tucson from Northern California I pulled off the freeway for gas (had about 1/4 tank still) and the van died on the off ramp once I slowed down. I thought well maybe I am out of gas because recently I had a bunch of electrical done to get the dash lights working and it went back out along with the fuel gage not registering all the time. So I put gas in both tanks and figured it should be ok. Nope started it up and it idled rough and died. It seemed to only stay running as long as I kept accelerating. It was about an hour to my friends house so I made it there and then tried to google the symptoms. I came up with either the IAC, the PVC or TPS. I bought the IAZ and PCV. Started with the PCV since it was easiest. Let it run about 5-10 minutes and it idled rough but seemed to stay going. So I started to make my way on the rest of my journey. Got 45 miles up the highway and this time it started to loose power on a straightaway. Accelerating did nothing, it just kept loosing speed but it was running. It would pop when trying to accelerate as if out of gas and it was worse so I just let it coast. I was hoping to make it to the exit but I didn't. Ended up getting a tow back to my friends. I need to get to AZ by Sunday so I need help diagnosing! Thanks for any help. I have the v8 5.0l. Has new plugs and wires. When trying to restart it has to turn over for a good bit ,maybe 30 seconds? before it starts rough
Old Jan 18, 2019 | 04:35 AM
JWA's Avatar
JWA
You seem to have ignition spark so the next logical thing to check is fuel pressure. This sounds a lot like that's not up to spec's.
Old Jan 18, 2019 | 09:32 AM
econo93's Avatar
econo93
Originally Posted by Chrystine Gimeno
..... as if out of gas.
When was the fuel filter last changed?
MC Dig
Nov 1, 2020 09:38 PM
rf15eagle
18
Jun 19, 2014 05:19 PM
slipnotic
1983 - 2012 Ranger & B-Series
Aug 5, 2005 07:51 PM
Sweetred95ta
Jul 26, 2005 09:23 AM
BigSix1
Dec 18, 2003 04:18 PM
