power steering
Old Jan 15, 2019 | 05:18 PM
j saladbar's Avatar
j saladbar
4wd Low
power steering
If adding power steering to a 1960 F 100 with 292 what pulleys will need ? thank you John
Old Jan 15, 2019 | 05:49 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
What vehicle are the P/S parts from?
Old Jan 15, 2019 | 07:07 PM
j saladbar's Avatar
j saladbar
4wd Low
power steering
plan to use aftermarket with toyota type steering box. just don't know if will need duel crank pulleys or water pump pulleys all the kits I have seen don't show pulleys thanks John
Old Jan 15, 2019 | 09:56 PM
HyePo57's Avatar
HyePo57
I have that from CCP (or was it CPP?)... anyway Saginaw pump i used a double water pump and double crank... one for the alt and the other for the P/S pump.
Old Jan 16, 2019 | 05:43 AM
Walston's Avatar
Walston
You have not told us what engine. Here is a pick of my 292 with eaton pump added. Second pulley bolts to the crank shaft pulley.
Old Jan 16, 2019 | 10:00 AM
j saladbar's Avatar
j saladbar
4wd Low
power steering
Thank you all lots of info. just have to hunt for pulleys. Will look for car parts thank you John
ike55
Apr 3, 2017 09:29 AM
Ripcity
Sep 14, 2013 09:08 PM
Matthew in SD
Jan 22, 2012 06:21 PM
1ole4d
Jun 17, 2007 02:03 PM
ROCKY1956
Apr 29, 2006 06:40 PM
