trans problem?
Old Jan 13, 2019 | 06:47 PM
fyrehose's Avatar
fyrehose
trans problem?
I have a strong shudder with loss of power while under strong acceleration. There are no noises just the strong shudder throughout the truck (driveline). The entire truck shakes. I believe it only does it when the torque converter is locked. Everything else is ok. Any ideas as to what the cause may be?
Old Jan 13, 2019 | 09:23 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Usually, it's one or more cylinders misfiring.
Old Jan 13, 2019 | 09:33 PM
fyrehose's Avatar
fyrehose
After reading a little bit, I am leaning toward u joints, or carrier bearing. Injectors are brand new. I had a bad injector which resembles more of a miss. This was a constant shuddering under throttle.
Old Jan 14, 2019 | 08:53 AM
Mark Kovalsky
Let us know what you find.
Old Jan 14, 2019 | 11:23 PM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
I'm betting 100 internet shekels on the carrier bearing.
Old Jan 15, 2019 | 08:43 PM
fyrehose's Avatar
fyrehose
I ended up checking the injector hold down bolts. I found the bolts a little loose. I was able to get about a half turn on the bolts until they reached 120 inch lbs. I am not sure if that would cause the shudder.
Old Jan 15, 2019 | 08:57 PM
DieselDenny's Avatar
DieselDenny
I'll bet 1 U joint. (If we're still allowed to say that)
Denny
Old Jul 21, 2019 | 03:23 PM
dmueller71's Avatar
dmueller71
So what ended up being the problem?
Old Jul 29, 2019 | 07:09 PM
fyrehose's Avatar
fyrehose
Bad HPOP. It would loose psi randomly.
Tooms789
Nov 30, 2016 05:05 PM
Fusion7.3
May 29, 2014 02:28 PM
79CEEJAY
Apr 6, 2013 12:06 AM
seamaster32
Jan 9, 2013 07:42 AM
TurtleRacing
Jan 14, 2008 03:22 PM
