Old Jan 13, 2019 | 09:11 AM
artscott61's Avatar
artscott61
Veteran: Navy
Ok I have never heard of a 391 but the seller say's it is an industrial engine with a steel crank . Also said that many parts will interchange. I just saw this yesterday and have never heard of a 391 but that does not mean anything. I would like to add to my collection of engines that don't run at the moment but I like them as garage art. I do not have an FE sitting in the shop I need one and also a nailhead.
(Update) I have seen some on the web here and will do more research. If anyone knows anything about them let me know.
Thanks
Old Jan 13, 2019 | 11:22 AM
85e150's Avatar
85e150
The 391 is designated as an "FT", and is a medium truck engine. It shares the same basic design with the FE engines but interchange is limited. No major components interchange. A Google search or a stroll through this forum will tell you more.
Old Jan 14, 2019 | 01:59 PM
baddad457's Avatar
baddad457
The block and rods interchange.
Old Jan 14, 2019 | 06:26 PM
85e150's Avatar
85e150
Block: FT moves to FE duty with a bushing for the distributor. FE doesn't move to FT. Rods, yup.
Old Jan 14, 2019 | 09:23 PM
baddad457's Avatar
baddad457
Cranks interchange as well, FT steel cranks can be machined to work in FE's. FE cranks were used in FT's as well.
Old Jan 14, 2019 | 10:13 PM
ford390gashog's Avatar
ford390gashog
The block and crank are valuable. Both are very strong, the block is high nickel and the crank is forged steel. The crank can be turned down to work with the FE timing cover.
Old Jan 14, 2019 | 11:25 PM
85e150's Avatar
85e150
Define "interchange". FE crank goes to FT with a bushing or FE front cover. FT crank won't go to FE without front cover change or machine work.
You can swap parts around if you have the decoder ring on what goes with what. Not sure the OP is going that deep, but I simply seek to avoid encouraging people to think that a simple change or two will make the FT slide right into their pickup.
Old Jan 15, 2019 | 08:26 AM
baddad457's Avatar
baddad457
Maybe you should define "interchange" you seem to have a different opinion of that than others. FE/FT's are the same engine family. Everyone who knows these engines are aware of this. I never implied that you could drop an FT engine into a pickup truck, But then again, there's the FT engines Uhaul used in their F350 rental trucks. Which could be construed as putting an FT into a pickup truck.
Old Jan 15, 2019 | 09:49 PM
Destroked 450's Avatar
Destroked 450
The 352/360 FE crank was used in the 330 medium duty FT engine, no FE crank was used in any of the heavy duty FT engines.
You can bush the distributor pilot hole in a FT block to build a FE engine.
To use a FT HD crank in a FE the flywheel mounting flange needs machining plus the crank snout needs turned down to FE size and new key ways cut for the timing chain and balancer.
The key ways must be cut in the correct location for proper timing gear and balancer alignment. Cost to convert a FT HD crank for FE use is high.
FT HD heads, intakes and exhaust manifolds will not interchange with some part from a FE.
The only direct swap parts between a FE and FT are rods, push rods and rocker assemblies.
Old Jan 15, 2019 | 10:15 PM
ford390gashog
The 389XD FT engine used by U Haul used a regular FE crank and timing cover as it was installed in F-350 Chassis cabs.
Old Jan 15, 2019 | 10:55 PM
Destroked 450
Pretty much a one off engine, doubt you'll find many laying around, never seen one myself, weren't they only used one year.
Old Jan 16, 2019 | 07:35 AM
baddad457's Avatar
baddad457
Originally Posted by Destroked 450
The 352/360 FT crank was used in the 330 medium duty FT engine, no FE crank was used in any of the heavy duty FT engines.
You're wrong about the 330 crank. I pulled a cast 352/360 crank from a 78 F600's 330. The 359 and 389's both used FE cranks.
Old Jan 16, 2019 | 10:00 AM
Destroked 450
Yes 330 medium duty used a standard 352/360 FE crank.
Never worked on 359/361 engines but they have the same stroke as the 330.
389 is a emissions detuned 391 that only came with the big snout steel FT crank, I've worked on a lot of these engines and have never seen one with a small snout FE crank.
Old Jan 17, 2019 | 08:34 PM
The Masked Rider's Avatar
The Masked Rider
Three fifty three ? . Just messen with ya. Summer is just around the corner guys.
Old Jan 17, 2019 | 10:51 PM
Destroked 450
Corrected, fingers are to big for the buttons sometimes.
