3.73
Old Jan 12, 2019 | 04:52 PM
elprofesor86's Avatar
elprofesor86
3.73
I have a 2017 F250 Diesel with 3.31. I am looking at towing a 5th wheel weighing in at 13328 dry and GVWR of 16670. If i do this, I'm thinking of upgrading gear ratio to 3.73, adding a leaf spring, new tires and air bags. I realize this doesn't change Ford's manufacturer's recommendations/guidelines but it basically turns my truck into an F350 with 3.73's. Has anyone done this or what are your thoughts?
Old Jan 12, 2019 | 05:07 PM
ford390gashog's Avatar
ford390gashog
Well Ford doesn't have a 3.73 option for diesel trucks. If you have 3.31 gears then you have the standard sterling axle, so you can find 3.73 gears if you want to do the swap.
Old Jan 12, 2019 | 07:49 PM
ssunit1's Avatar
ssunit1
. My‘15 had 3:73’s.
Anyway, my 5er is very close to yours in weight. I added bags and compressor to level the load, didn’t need the extra springs just for the trailer. I did change the shocks for Bilsteins. You may want to check the towing specs, if you haven’t already, to see if the gearing change is really needed. Little bit bigger project than bags and shocks. I would get higher rated tires than stock.
Welcome to the forum. Happy camping.
Old Jan 12, 2019 | 11:59 PM
Army RET's Avatar
Army RET
My thoughts: while your F250 will pull it ...
you are (unfortunately) another example where salesmen/ proud internet users have seriously led you astray.
To safely pull a (16K# +) load you need a 4.10 dually F350, with a GVWR rating of 14K.
To be somewhat within your current specs you shouldn't exceed (a carefully loaded) 10K pound fifth wheel.
Old Jan 13, 2019 | 11:12 AM
First Dually's Avatar
First Dually
Originally Posted by elprofesor86
I have a 2017 F250 Diesel with 3.31. I am looking at towing a 5th wheel weighing in at 13328 dry and GVWR of 16670. ...
That's one heck of a lot of trailer for a 3/4 ton truck!
I'd seriously consider and different truck or trailer.
Old Jan 13, 2019 | 11:34 AM
crewzer's Avatar
crewzer
Question
Tell us more about your truck. For example, what is the cab and bed configuration, and is it fitted with the optional High Capacity Trailer Tow Package?
Regards,
Jim / crewzer
Old Jan 13, 2019 | 01:33 PM
scraprat's Avatar
scraprat
Top Answer: 5
The OP will gain nothing by changing gears other than spending money where not needed and thinking he'll gain more power to pull more weight. Here is the screen shot from the 2017 brochure...diesel 250s have the same gears as the 350s yet the 350s are rated for more and other than components added to carry more/ handle more weight so they're basically the same truck till "registration" time.
Old Jan 13, 2019 | 01:57 PM
crewzer's Avatar
crewzer
And here from the 2017 Super Duty sales brochure are the footnotes associated with some of the values shown in the chart above:
(1) Pickup box delete.
(2) Requires F-250 High-Capacity Trailer Tow Package.
(3) Gooseneck tow rating shown. 5th-wheel tow rating limited to 5th-wheel hitch rating of 18,000 lbs.
(4) Gooseneck tow rating shown. 5th-wheel tow rating limited to 5th-wheel hitch rating of 27,500 lbs.
HTH,
Jim / crewzer
Old Jan 13, 2019 | 02:37 PM
scraprat's Avatar
scraprat
Top Answer: 5
#2 pertains to F250s
#3 pertains to the F350 SRW
#4 pertains to the F350 DRW & F450
Old Jan 13, 2019 | 02:57 PM
First Dually
A 5th wheel with a gross of 16670# will have a pin weight in the range of low 3000# to over 4000#. The OP will likely be over cargo carrying capacity before any cargo is added!
Old Jan 13, 2019 | 05:41 PM
00t444e's Avatar
00t444e
I would get a dually to tow a 5th wheel that size.
Old Jan 13, 2019 | 05:42 PM
elprofesor86
I will never be pulling 16000#. 14,500 - 15,000 which the truck is rated for as configured.
Old Jan 13, 2019 | 05:45 PM
elprofesor86
I have the tow capacity package
Old Jan 13, 2019 | 05:46 PM
elprofesor86
Pin weight is 2670. Cargo weight for my set up is 3450
Old Jan 13, 2019 | 07:02 PM
WE3ZS's Avatar
WE3ZS
Is that pin weight from a truck scale or sales brochure? If it's from the manufacturer it, like all other factory trailer specs is a mixture of guesstimating and fantasy, real world numbers are always higher than advertised for a number of reasons. My TT's advertised tongue weight is over 600 lbs lower than what it scales at loaded for camping with zero water onboard.
It sounds like a bigger truck or a smaller trailer would be a better option than what you have mentioned above.
