Need Replacement Radiator– Which one?
Old Jan 12, 2019 | 10:35 AM
User 32921's Avatar
User 32921
Question Need Replacement Radiator– Which one?
Just noticed that the bottom of my radiator seems to be leaking. My truck is a 1978 F150, 351M/400, Automatic. Not sure what radiator would be a direct replacement or what possible upgrade options I have (and what other parts I would need to do that). On a side note, I noticed that the lines going to and from the transmission cooler portion of the radiator were cold to the touch, clogged maybe?
Here are some pictures of my current radiator with transmission cooler:
Old Jan 12, 2019 | 04:05 PM
TWISTER324's Avatar
TWISTER324
Also interested
Old Jan 12, 2019 | 07:56 PM
440 sixpack's Avatar
440 sixpack
If originality is important I'd either recore it or get a copper replacement. neither is cheap.
if you just want it to work there are 100 options in aftermarket radiators. the aluminum/plastic ones are the cheapest and they work fine. they're all imported so I'm not sure one is much better than the other.
Old Jan 12, 2019 | 08:01 PM
ranger140892's Avatar
ranger140892
Grumpy goat
Champion radiators
https://www.championradiators.com/Fo...ll-side-mounts
Old Jan 12, 2019 | 09:01 PM
79 ranger 4x4's Avatar
79 ranger 4x4
This is what I used for a better than stock replacement for my copper one. Everything bolted right up even used the stock shroud just had to drill two holes on the side mounts for the shroud to bolt at the top. Runs cooler than stock between half and 1/4 gauge. Heat will run you out of the cab and the shiny factor doesn’t hurt either
Old Jan 13, 2019 | 02:59 AM
JohnBOV43159's Avatar
JohnBOV43159
I have had a Champion 3 core with my 400 for about 5 years, couldn’t be happier. I don’t have a trans cooler. You can call them and they will build it how you want
Old Jan 13, 2019 | 07:37 AM
ranger140892
Grumpy goat
I bought one about a year ago. When I called Champion I asked for a radiator without a trans cooler. The rep told me that all their radiators have them now.
Old Jan 13, 2019 | 08:18 AM
Dave145's Avatar
Dave145
Sounds like it's time for someone to search the auto parts store's websites...
Old Jan 13, 2019 | 11:50 AM
User 32921's Avatar
User 32921
Sounds to me like you missed the part where I asked what upgrade options there were out there.
Anyways,I will be looking into a Champion radiator. Not much more expensive than the plastic+aluminum ones they carry in the parts stores and sounds like an upgrade over direct-replacement.
Old Jan 13, 2019 | 07:19 PM
ranger140892
Grumpy goat
For the price difference, I sure wouldn't chose a three row over a four row. Ida bought a 8 row if they made them.
Old Jan 13, 2019 | 07:23 PM
ford390gashog's Avatar
ford390gashog
The champion radiators are direct replacements. No modifications needed. I have probably used 30 or 40 of them so far in various vehicles and no issues. If you don't need the transmission cooler just leave it plugged.
Old Jan 13, 2019 | 11:59 PM
54Hydro's Avatar
54Hydro
My brothers and I all have Champions, no issues x3. Before they started making the larger core sized ones to replace the "Super cooler", I ordered a Ebay special one. It came with a warp made into it. Middle brother ordered an aluminum elsewhere before his Champion, quality was crap. Looked like a blind two year old welded it with his feet, and he warrantied it immediately for a leak. Avoid the cheapo specials.
Old Jan 23, 2019 | 03:21 PM
myrtlehead's Avatar
myrtlehead
Trying to get a radiator for a 79 F350. To fix mine is $800-$900,prices from 3 different shops across the state. The new Jeg's has a Champion 4 row (part # 166-mc-433 for 68-79 F-series trucks) for $342. Always thought fixing the original was the way to go but after hearing every one say positive things about the 3 row I am not sure what to do.
Old Jan 23, 2019 | 04:32 PM
jakeharp's Avatar
jakeharp
Ive had good luck with the champion i put in a few years back, just make sure you put a 13psi stant cap on with an overflow capture...
https://www.ford-trucks.com/forums/1...iator-cap.html
Old Jan 23, 2019 | 04:39 PM
ford390gashog
You can get a better price search a little more. I paid 289.00 delivered on my 4 core Champion.
