Reverse/brake light on dim truck off/locked
Old Jan 11, 2019 | 08:39 PM
Slapshottr's Avatar
Slapshottr
I have a 2014 F550 flatbed. Two weeks ago reverse lights were on bright when truck was off and locked. Unlocked and started truck put it in reverse then drive (D) moved it 2 feet and problem fixed. This did not happen again and figured it was something to do with reverse. Today turned truck off locked it and reverse and brake lights came on very dim. Unlock started truck turned headlights on and all rear lights brake and reverse are out. Turn headlight switch off with truck running and brake light and reverse on dim. No electrical work done to truck as far as wiring goes. One month ago put a battery in truck everything working fine. Only work done on truck.
Old Jan 12, 2019 | 08:17 AM
Franklin2's Avatar
Franklin2
First thing to check is the wiring to the rear lights. Being it is a flatbed, I am going to assume the rear lights were not wired at the factory, but wired by the body builder (whoever put the flatbed on it). I would check their wiring and their splices, and check for the ground and make sure it's not corroded.
Old Jan 12, 2019 | 10:53 AM
alloro's Avatar
alloro
Check your battery to body to engine block grounds to make sure they're all clean and tight.
F350-6
17
Jun 28, 2015 09:18 AM
Jrod67
Nov 11, 2014 06:22 PM
Socal82bronco
Electrical Systems/Wiring
Feb 9, 2014 07:23 AM
Superduty.pride
Oct 21, 2011 12:10 PM
cpearson
Mar 11, 2004 07:58 PM
