Funny squeely sound
Old Oct 9, 2003 | 10:17 AM
Daddywags's Avatar
Daddywags
Yeah, engaging/disengaging the clutch makes no diff - noise is still there. I'm not sure when I can get into this, mabye this weekend due to a change in my work schedule, but 'sfar as the input bearing or bushing is concerned, how do I remove it (assuming it's the culprit?) And how do I check the tranny bearing to make sure it's not on the way out as well?
Old Oct 9, 2003 | 10:36 AM
smcafee's Avatar
smcafee
If the noise is loud in third gear and goes away in fourth, the front transmission bearing is bad. Replacing the pilot or throwout bearing requires the removal of the transmission and the pilot bearing is then pulled from the end of the crank. Big job. If the noise is constant with clutch in or out and driving or idling there might be something making contact with the flywheel. (wild guess)
j_hurst369
6.4L Power Stroke Diesel
29
Jan 25, 2024 07:31 AM
I8AHEMI
Apr 7, 2016 06:41 PM
tross
6.7L Power Stroke Diesel
Jan 31, 2014 09:19 AM
dizzy d
Dec 14, 2008 06:54 AM
franklin411
13
Oct 29, 2003 07:30 PM
