AC/Vent blower motor
Old Apr 6, 2016 | 10:17 PM
I8AHEMI's Avatar
I8AHEMI
Ok all, I have searched the forum and could not get find what I was looking for, so here is my issue...
When I turn on my fan for the AC or vent or heat, it works just fine on the first and second settings. When I move the fan speed to the third and last speed, I hear this sound that sounds like the blower fan is hitting something. I turn the speed back to the lower two settings and noise goes away. Sometimes I turn it back to the higher settings and the noise actually will go away but most of the time the noise is there.
I pulled the blower motor out yesterday and set it to where I can turn it on while out of the compartment and I didn't really notice a noise. I wonder if the noise is there but I am just not hearing it since it is not enclosed in the compartment? I also noticed there is a crack in the fan where it mounts to the shaft starting at the shaft and extending out one direction and also 180 degrees the other direction.
Thoughts on if the motor is bad or just the fan? Or even something else that I may not be seeing?
Thanks!
Old Apr 6, 2016 | 11:16 PM
dlragalie's Avatar
dlragalie
Open it up and take a peak on the inside, it may be something stupid (like a leaf??), or you need a new fan-blower thing. Cracked does not sound promising...
Old Apr 7, 2016 | 08:27 AM
mueckster's Avatar
mueckster
If the squirrel cage (fan) is cracked, it is probably expanding/vibrating enough at the higher speeds to hit the case. I've seen this happen on other vehicles. Sounds it just needs the new fan.
Old Apr 7, 2016 | 09:35 AM
Jaime74656's Avatar
Jaime74656
I am in agreement, mine is starting to make a noise (different then what you describe) but its slated to go away and be replaced asap...I just dont look forward to it as I got to remove some other bits I think...but meh....could be worse...
Old Apr 7, 2016 | 06:41 PM
I8AHEMI's Avatar
I8AHEMI
Thanks all for the thoughts. I suspected the squirrel cage since it is cracked but just wanted to see if there was anything I may have missed. I didn't see any leaves or such in the box so I would venture to say the squirrel cage is the culprit. I'll provide updates when I finally get around to changing it out.
twfs
2009 - 2014 F150
Nov 19, 2017 07:58 AM
muddyford75
Feb 13, 2005 09:11 PM
defibvt
1983 - 2012 Ranger & B-Series
Sep 18, 2004 09:17 PM
cow_boy104
Aug 16, 2003 12:21 AM
Lakeitel
Jul 27, 2003 08:58 AM
