2000 ranger engine breaking down over 3k rpm's
Old Jan 11, 2019 | 11:53 AM
rangergolfer's Avatar
rangergolfer
My 2000 ranger 3.0v6 flexfuel engine is breaking down over 3k rpm's, I posted last year about my truck breaking down at any speed so here is what I replaced, fuel filter,plugs& wires, coil, air filter, which cleared up about 95% of the problem as the truck runs great until I get over 3k rpms, it's not a big problem but it could be as in a passing situation, any help would be appreciated.
I have a elm scan tool and the forscan app but no codes are showing.
Edit to add that I ran two bottles of Techron but no joy.
Old Jan 12, 2019 | 09:00 AM
pawpaw's Avatar
pawpaw
Scan the ECM computer for trouble code clues & post All code Numbers, as they can help focus a trouble shoot.
Is the cut out happening on the road when your accelerating under load, or at rest when your revving the engine? If its happening when not moving & revving the engine, you may be bumping the ECM rev limiter, programmed in there to prevent no load engine over speed & having it come unraveled.
If its happening while driving & getting close to, or going through this rpm range, then a number of things come on the suspect list & pending, or set trouble code clues will help define where best to focus your trouble shoot.
Seeing as how you say your 3.0L is a flex fuel engine & its a "waste spark" ignition system, did you use the Specified plugs, wires, coil pack, fuel pump & filter?
Have you checked your work, to make sure the plug wires are routed exactly as the factory had them & that they're still securely fastened ?
Have you raised the hood at night & revved the engine to that level while looking for arcs & sparks from the plugs, wires & coil pack, or given them a "wet down" test, to see if you may have faulty, or damaged insulation?
Have you performed a fuel pressure & delivery rate test, to make sure fuel pressure is up to snuff & that the pump & fuel lines are able to deliver enough fuel Volume at higher rpm? (thinking maybe a mashed, or kinked fuel line or hose. or maybe a faulty gas cap not properly venting the tank to equalize the pressure, or something like that) Anyway trouble code clues will tell you where best to look next. Let us know what you find.
decemberwyatt
May 3, 2018 08:39 AM
dwpeugh
1997 - 2003 F150
May 25, 2017 07:43 AM
SpikeTWD
Dec 7, 2008 10:39 PM
ArizonaDPS
3.0L V6
May 27, 2004 06:38 AM
becf150
1997 - 2003 F150
Mar 10, 2002 12:50 AM
