fuel pump cutoff switch location
Old Sep 28, 2003 | 06:31 PM
wrangler's Avatar
wrangler
Question fuel pump cutoff switch location
ok heres the deal,
91 aerostar 40,000+ miles, 3.0 motor van was run untill gas tank was dry, filled tank, van would not start. put pressure gage on test **** @ fuel rail, showed no pressure. fuel pump is audiable, and relays have power. asked around and was told to check fuel pump cutoff switch and reset. however owners manual is not in van.
two qestions.
location of fuel pump cutoff switch.
if fuel system is vapor locked what is the easiest way to bleed pressure and re-prime.
thanx in advance
Old Sep 28, 2003 | 06:37 PM
stepman's Avatar
stepman
If you can hear the pump, the switch will not be your problem as it cuts the power to the pump. I would say that since the tank was run dry and you can hear the pump run that the pump is bad. The fuel in the tank helps cool the pump to keep it from overheating.
This thing doesn't have two pumps, does it?
Old Sep 28, 2003 | 06:46 PM
wrangler's Avatar
wrangler
its not my van, i'm sure its just a single pump its a single tank and theres only one harness goin into the tank.
Old Sep 28, 2003 | 07:27 PM
stepman's Avatar
stepman
What I was wondering (not familar with THESE vans) was if it ran the high press pump like the E & F series vans.
Old Sep 28, 2003 | 07:42 PM
wrangler's Avatar
wrangler
lol i'm not either i think they're crap, you know when you have to pull off both front tires to change the plugs some engineer had his head in his a** but no just a single pump, i plan on pulling the fuel line away from the filter and see if the pump will send it that far, if not i guess i'll have to pull the pump out and replace it
Old Sep 28, 2003 | 07:50 PM
stepman's Avatar
stepman
Thats a good place to start. Maybe plugged filter. If not, bad pump.
Old Sep 28, 2003 | 07:58 PM
wrangler's Avatar
wrangler
i appreciate your help. take it easy
brendo613
Jun 17, 2016 05:50 AM
Davie J.
Jun 7, 2016 11:47 AM
dbrydon
Jan 5, 2016 02:37 AM
voodoolord
Aug 27, 2015 03:45 PM
voodoolord
Aug 27, 2015 07:53 AM
