Aftermarket Products
Sponsored by: Worksport
On board air
Old Jan 6, 2019 | 03:24 PM
Pennsyltuckian's Avatar
Pennsyltuckian
On board air
i need some way to protect my air quick connect coupler. What is everyone else doing with their on board air couplers to protect them from the elements?
Old Jan 12, 2019 | 08:37 AM
wpnaes's Avatar
wpnaes
I’ve been adding a little motor oil to a plastic bag, then wire it over the fitting. I use the fitting 2-3x a year. Inconvenient, but keeps it working when I need it.
Old Jan 13, 2019 | 04:52 AM
tjc transport's Avatar
tjc transport
i ain't rite
i have mine on the inside of the bed at the tailgate on the 02. bed cover protects it. the other trucks have portable compressors.
Old Feb 18, 2019 | 06:01 AM
DAVID WERTZ's Avatar
DAVID WERTZ
Tennis anyone??
I have an externally mounted quick connect on my tow truck and I've found the best way to keep it clean is to take a tennis ball and with a box cutter or other sharp knife, make a horizontal cut the width of the blade, (that's why i use a razor, 1" is about perfect) then make a vertical cut intersecting the first one, basically making a "plus sign" with the cuts. Push it over the quick connect, give it a twist or two and you're set. Cheap and easy and it'll last for quite a while.
Old Feb 26, 2019 | 04:24 PM
Squirrel13's Avatar
Squirrel13
Honestly the only way to truly protect it to mount it inside out of the elements. Some of the solutions mentioned will delay corrosion, but in the rust belt with high humidity they are going to get bad. On my Jeep the fittings are inside each from door. On my excursion they are mounted inside the rear HVAC compartment
Pladsmand
Nov 29, 2018 01:28 PM
Caveman Eric
Oct 22, 2017 07:52 PM
shortride
Jul 6, 2017 10:55 PM
Copper50F1
Jul 2, 2015 03:05 PM
MikePacey
30
Sep 5, 2011 04:52 PM
