4x4 hub.
Old Jan 5, 2019 | 06:42 PM
Stroker 6.0 fan's Avatar
Stroker 6.0 fan
4x4 hub.
Just got back from the snow. Used the 4 wheel drive for first time on my truck. When I turned the hub locks from locked to auto, air bubbles came from the ford emblem in the middle of the **** then stopped after a few seconds. Is this normal? Thanks
Old Jan 5, 2019 | 06:56 PM
WatsonR's Avatar
WatsonR
Normally, shifting the switch inside the cab from 4x4 to 2 WD causes the vacuum to pulse the hub for 20-30 seconds to either lock or unlock the hub when it's in auto. Moving it manually just spins the engaging center section. Maybe it's full of grease or water and it pushed out the air? Might mean the seals are good as well. Check them, takes 5 minutes to do both. Turning the hub doesn't pulse the vacuum.
Old Jan 5, 2019 | 08:16 PM
Stroker 6.0 fan
Ok. Thanks.
Kemicalburns
Dec 19, 2016 02:20 PM
Garythelegend
Oct 20, 2015 08:48 AM
cabloom300
Dec 17, 2014 12:33 PM
ironmine
Nov 16, 2005 08:51 AM
Steve_250
Jun 7, 2005 07:49 AM
